Craftsman 11HP, 30inch, dual stage snow blower mode C950-52151-1
You buy by make model not by size!
Craftsman C950-52021-0 gas snowblower parts ' Sears ...
www.searspartsdirect.com > model > craftsman-c950-5...
Here are the diagrams and repair parts for Craftsman C950-52021-0 snow blower, ... snow build-up in auger housing, broken auger shear pins, auger drive belt ...
Craftsman Snowblower ' C950-52021-0 ' eReplacementParts ...
www.ereplacementparts.com > craftsman-c950520210-sn...
Craftsman. We Sell Only Genuine Craftsman Parts. Craftsman C950-52021-0 Snowblower Parts. Search within model ... Auger Drive Belt. $20.59. Part Number: ...
Traction Drive Belt - Craftsman C950-52915-0 ... - ManualsLib
www.manualslib.com > ... > Owner's manual
Belt Replacement; Auger Drive Belt; Traction Drive Belt - Craftsman C950-52915-0 Owner's Manual. Dual stage snow blower 5 h.p. 24 inch. Show thumbs.
Craftsman Snowblower Belt Replacement Parts ' Fast ...
www.repairclinic.com > Shop-For-Parts > Craftsman-Sn...
Snowblower auger drive belt. MTD has changed the design from a cogged belt to a V-Belt. Both belts will function with your equipment. Craftsman Snowblower V- ...
Certified Snowblower Auger Belt, 3/8 x 34.4-in Canadian Tire
www.canadiantire.ca > pdp > certified-snowblower-aug...
Snowblower auger and transmission drive belt Transmission drive belt fits 500/600 series ... Craftsman, Yard Machines, MTD, MTD Pro, Troy-Bilt, Huskee.
Https://www.google.com/search?q=C950-52151-1&rlz=1C1CHBF_enUS757US757&oq=C950-52151-1&aqs=chrome..69i57.655j0j4&sourceid=chrome&ie=UTF-8
SOURCE: Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
SOURCE: craftsman 8hp snowblower starts but will not stay
Your snowblower carburator is gummed up. Go to an auto parts store and get a can of a carb. cleaner called seafoam. Follow the directions as far as how much to put into the snowblower gas tank. Run it for a few minutes and it will clear up. Regards, Joe
PS Please rate my answer. Thank you.
SOURCE: Craftsman Snowblower. One auger is
the augers on many craftsman snowblowers have a sheer bolt. If the auger encounters too much resistance, ie, a foreign object like a piece of wood or even a newspaper buried in the snow, this bolt will break off preventing damage to the gear box, which is a lot more expensive to repair than replacing the bolt.
This bolt requires not tools to install, just insert and secure with a cotter pin.
The parts dept at sears can sell you the replacement bolts with the correct sheer force rating. Have your snow blower model number handy when you call or go in.
SOURCE: I need a replacement belt
Sears will not tell you what size of belt you need. They only list parts by part number. But this machine uses MTD belts and you can get them at searspartsdirect.com or your local mower shop can order them through MTD.
Part Listing: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Snow-removal-equipment-Parts/Model-247886640/0247/1507200?sid=MMLxMerchandizexManualsModelxcraftsman%2088664x247886640
Manual: http://www.managemylife.com/mmh/owner_manuals/search?query=craftsman+88664
Here are the two part numbers for the two belts on the machine. MTD Part #: 954-0343
and #: 954-0430B
Any other questions, please ask. Remember to rate this answer if it helped.
I have tried 1/2 x 38 - takes full tension adjustment & slips so too long Traction belt which came off was too long at 3/8 x 33.7
