Even when I place the WT3 on it's charger, it just will not charge up. Can the battery be replaced?
Yes, batteries are readily available.
https://www.google.com/search?q=golf+buddy+wt3+battery+replacement
SOURCE: trickle charger for storing electric cushman golf cart
contact manufacturer, and seek there advice
SOURCE: Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
SOURCE: low battery, won't charge
connect the garmin to your computer using the usb port. It will start charging then. For some reason when the battery goes dead in this unit the only way to charge it is with computer. the car adaptor will not work once the battery gets real low.
SOURCE: phone not charging even with new batteries
Reboot your phone system. I'm not kidding. Unplug base from power and phone line for 1/2 hour and unplug battery from phone.
SOURCE: New Hitachi 3.6v HXP EBM315 Li-ion battery won't take a charge
when i turn on my drill amoked comes out hohw can i fixed it????
