Question about Amana Washing Machines
I have a Amana top load washer, it will light up the "sensing fill" light. And fill but then once it gets "filled" it will drain and the light will go out and will not continue it cycle. But my light for "wash" will turn on. I have checked the u shaped drain tube and I have also unplugged it from the electric outlet.
  • Chris Huff
    Chris Huff Dec 26, 2018
    Had that always been the case?
  • Ashley Dec 26, 2018
    Yes it was only locking when it began the rinse/spin cycle
    Top Expert:
  • Amana Master
  • 6,289 Answers
Check lid lock
Posted on Dec 26, 2018
    When it is sensing filling the lid do not lock.
SOURCE:
Buffalo12980
  • 625 Answers
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Posted on Sep 02, 2007
dididsaythat
  • 291 Answers
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
  • 1073 Answers
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Posted on Apr 20, 2008
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
WASHER ... COMES ON GREEN SENSING LIGHT STAYS ON START'S TO FILL CLICK'S OFF RED DOOR LIGHT LOCK LIGHT COMES ON STAY'S BLINKING
Thank you first person that has provided a model number sounds like you already changed the lid lock assembly if you did you know how to get the top up inside the front panel is a tech sheet it will tell you how to place the unit into diagnostic and read the lights for an error code recheck your connection at the control board a flashing lid lock would should give and F5E1 or F5E2 error code also check the alinement of the tab on the lid where it goes into the lock assembly should be a smooth transition
Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. Top Load...
How to calibrate amana top load washing machine
The fill control valve may have failed (despite the green filling light).
Sep 08, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
Amana NTW4700YQ Top Load Washer will not drain
Hopefully you have it under warranty. You will probably need another wire harness. Double check your outlet to make sure it is grounded properly because they will 'nit pick' and tell you it is your fault for not having a properly grounded outlet.
Jul 20, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
The washer fills and drains, but won't agitate
sounds like the clutch is not properly engaging and if this is the case it usually meens it has to be replaced
Oct 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Amana top load washer fills with water and will not stop filling
Hi...
You need to check this
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
Good luck !!!
Regards
PCmania
Jul 07, 2009 | Amana Washing Machines
Water fill control
it overflows from the tub then:
This can either be a fault in the fill sense tube( small tube connected to the bottom on the outer tub from the sensor at or near the top of the washer housing ) becoming blocked or broken or a fault with the sensor itself. There is a mechanical adjustment for the level but it is a little fiddly to get the adjustment just right.
If it overfills from the drain hose:
then either the drain hose is too low and the water siphons out before it reaches the maximum or there is a tight seal at the drain hose to house drain port which will cause all the water to siphon out, this can also be caused by a drain hose being pushed too far down the house drain port.
Jul 28, 2008 | GE WDSR2080D Top Load Washer
Water Drains out as fast as it is filling
You have too much of the drain hose inside the drain line causing the water to siphen out as its coming in. Pull some of the drain hose out and secure the hose. There should only be about 8 inches or so of the hose inside the pipe.
Apr 08, 2008 | Amana ALW880WH Top Load Washer
Machine fills and drains
raise your stand pipe up alittle bit lower of the machine
Sep 20, 2007 | Amana DLW330RA Top Load Washer
Washing Machines Logo
Top Amana Washing Machines Experts
Sal De
Mike
Gerry Harvey
Gerry Harvey
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
