Question about Jensen Car Audio & Video
My antenna broke off flush to my Jensen cd-555. How can I pull the back of the radio to attach a new one.
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 157 Answers
You can buy an antenna multi plug adapter kit. Cheap. You can use it to plug into.
Posted on Dec 26, 2018
SOURCE:
  • 18 Answers
SOURCE: 2004 Mercury Sable, Want access to antenna plug in back of radio
The control panel is held in by 4 internal clips which are inside the four holes at the edges of the panel. Take 2 pieces of coat hanger and bend them into a U-shape and insert one into the two holes on the left, and the other into the two holes on the right. About 1-1/2 inches until you feel the clips release. Using the hangers like handles, sort of push outwards on each one and pull the panel towards you. There are electrical connectors and vacuum connectors back there, so don't go crazy. Disconnect them depending on what you're doing. When you put it back in, make sure the rear support engages the support rail in there, and make sure the clips snap in place
Posted on Nov 16, 2008
  • 6 Answers
SOURCE: how to replace an antenna on a 1988 honda accord.
Ouch! I haven't tried this myself, but would electrician's tape work? Try feeding it from either end...
Posted on Feb 04, 2009
  • 105 Answers
SOURCE: Jensen 2006 7" indash touch screen: CD player wont work
Try a lens cleaner . If that doesn't work then it would have to be repaired.
Posted on May 18, 2009
SOURCE: Pin in back of receiver broke off
If you can put your hands on another unit for parts, you can open it and replace your damaged pin with one from the unit for parts. It takes a little time and care but you can do it.
Posted on Aug 18, 2009
kb8dns
  • 494 Answers
SOURCE: broken antenna on grundig mini 300 radio
Replacement is possible, the back of the radio needs to come off and there is a screw at the bottom of the antenna. Remove this and the old one will slide out and simple to install new one. Call Eton for replacement, can be foung with a google search....
Posted on Feb 14, 2010
My Jensen MCD 5110 Marine radio acts like the antenna is unplugged. I can't figure out how to remove the radio from it's sleeve to re-plug the antenna jack (if that is the problem)
I don't know much about marine radios. I am a ham radio operator, but they are much the same, if you do not hear any static (with squelch control turned down), then I suspect you are correct about the antenna. It could be the antenna itself, or the coax line to it, or the connection point at the radio or at the antenna. You're stuck without being able to remove it. If you do and find nothing at the radio, you'll need to check the connection at the antenna etc. Good luck.
Nov 21, 2014 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
Have a 5" portable jensen tv/radio - no picture - how to attach a converter?
If it's one of the newer models that has the input for an antenna on the back then you can go buy the adapter at radio shack that allows you to hook it up with coaxial with either a converter box or a converter box with an antenna. The attachment looks like a 3.5 audio jack.
Oct 31, 2012 | Televison & Video
2002 Chrysler Town & Country antenna installation
Did the antenna break off in the mount or did the mount break.If antenna broke off in mount I would try drilling and tapping it.If you need a whole mount.Remove plug from back of radio attach good mechanics wire to it undo outer mount when you pull the wire out of the car the mechanics wire will follow afer you get it out put the mechanics wire on the new one tape over the wire to make it a smooth transition and pull mechanics wire inside the vehicle to reroute the antenna wire back to the radio.Be carefull you shouldnt have to pull super hard
Jun 04, 2012 | 2002 Chrysler Town & Country
Power antenna broke and I need to replace it. How
Buy replacement antenna mast. Remove old one by unscrewing the retaining cap nut. Turn on the radio & let the antenna cable run all the way up while you pull on it to remove it.
Install the new antenna mast by turning the radio 'off' so the spool inside goes back to its beginning while you feed the cable of the new antenna down into the antenna mast hole.
Once the cable is all the way down, reinstall the retaining nut/cap and turn on the radio to allow the spool to run the antenna 'UP.'... cycle the radio ON and then OFF several times allowing the antenna to move all the way up and all the way down.
That's it!
Sep 28, 2009 | 2001 Hyundai Sonata
The antenna base on my Maxon HCB-10C CB Radio got pulled out. Can I fix this?
Not sure what you mean here...
If the antenna is broke, then you should just get a new antenna. If the antenna connector was pulled out of the radio, it is usually fixable.
If the connector is broke off the antenna, it may may be fixable, I would have to see it. If its done wrong, you could hurt the transmit section of the radio.
You should just get a new antenna.
Sep 25, 2009 | Maxon HCB-10C CB Radio
Jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
May 19, 2009 | Jensen VM9510 Car DVD Player
Antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
Antennae broke
Just go to any radio shack they have lots of antennas
Oct 27, 2008 | RCA RCD110 Radio/Cassette/CD Boombox
Car Audio & Video Logo
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
