The Ford 6640 provides 67 HP at the drawbar and is rated at 76 HP at the PTO. See http://www.tractordata.com/farm-tractors/005/9/5/5951-ford-6640.html for the specifications.
I hope this helps.
SOURCE: I have an old Columbia Garden tractor is this a MTD
go to partstree.com put your make and model# in and click the year you need from the engine window it should get you close to what you need .hope this helps
SOURCE: Starter
Take the part with the info you have to a Briggs authorized parts place ... they can help you .
SOURCE: 42" lawn tractor model 917.272082,
some of these have oil sensors.. you could bypass it just to check if this is the problem .. check the oil !! there is a solenoid on the carb also that shuts the gas off..jay
Clutch plate slippage.
