SOURCE: wii remotes
Open the front flap on the wii, hold down the red button there for about 3 seconds then take the battery cover off the wii remote & press the red button there too for a few seconds. then press A on wii remote, that should work for you
SOURCE: Sync the Remote to Cable Box?
I'm having the same problem but I do know that you need to sync the remote w/the cable box. My cable box is Dolby, which is where my problem comes in. I can't find a code anywhere to sync the/any remote w/a Dolby cable box.
SOURCE: Can't sync wii remotes to console
When you sync the wii motes you have to do it in proper order!!!
There are 2 ways to sync one is minor out of sync stuff. You push red button on the wii briefly then quickly press the red button on the wiimote.
Second one is what you need to do. First remove any disk then hold in the power button until the light turns red. (not yellow or orange). Release it then unplug the Wii. Do not remove the batteries but if they are low replace them before you turn it back on. Wait at least 2 minutes.
Have the backs off the Wiimotes.
Plug the Wii in.
Turn the power on.
As the Health and Safety screen appears push in the red button on the Wii.
Hold it there a min. of 15 seconds. 25-30 is better.
When you release it right away push the red button on the first Wii mote. It flashes all the lights.
Immediately press then release the red button on the Wiimote while lights are flashing. When they stop flashing it will be synched.
a.Then press the button on the Wii again (this time only hold for 2-3 seconds) then press the red button on the second wiimote and while lights flash press the button on the Wii again.
Repeat a. for any other wiimotes.
SOURCE: Gyration remote control will not sync with the rf receiver.
I had this issue and this is what I did.
1: Control panel
2: Double click Mouse (To access "Mouse Properties)
3: On top click Hardware
4 Check how many hardwares you have and one by one highlight them and click properties and update the drivers.
Try that and post any message
SOURCE: I synced it to the tv but I dont know how to sync it to the xbox
You shouldn't need to sync it to your x-box.
By clicking on the TV button it will change from your TV to the XBox.
