SOURCE: no heat in either oven
May I please have some more information. How do you know you have electricity, because the display is on, inside lights etc. Have you checked the voltage from the wall? It is possible on 220v appliances that 1/2 of the breaker has tripped, thus all the 110v systems work (like lights) except the heating elements, which are 220v. Because both ovens have the same problem, its most likely a power source problem.
SOURCE: dcs oven display dim - need part #
I just did this same repair...same part number as above (Part #211696 "Electronic Oven Control, Double).
to install you have to remove two screws on the top of the display section of the oven, as well as several screws on the bottom of it, and the screws holding the close pin/temperature probe socket.
Then you can pull off the whole top section (slowly) and remove the two connectors to the existing control unit.
Then release the ribbon cable connected to the control unit on the inside of the top section (press the two small pins inward and slide up the small front section of the black socket to release the ribbon connector.
Unscrew the old control panel, screw in the new one, connect the ribbon, and then reverse removal steps. Easy!
SOURCE: Where can I find part no 211696 for dcs oven?
what is this part called and where did you get the part number,then i will help.
SOURCE: Need part for dcs oven thermostat model dcs60-24g6-2n
https://www.searspartsdirect.com/model-number/RGSC305BK/3232/0124002.html
You can try this site
If you need further help, I’m available over the phone at https://www.6ya.com/expert/daniel_a4640839dbb7ec58
