SOURCE: Start/pause switch works intermittently. How do I
i have found that the micro switch burns out on them and needs to be replaced. remove rear screws remove top cover , remove shield the unclip cables and front panel
Use a multi meter to test micro swicth on circuit board replace if faultsy
SOURCE: how do I get into the side panel to replace a faulty power window switch?
take the door panel off,there should be screws in your arm rest and where your handle extends from .the rest are just plastic connectors the switch should be visible it usually requires that you push in and up to remove it
SOURCE: bought a powertech 1500w 24v
Hi funtimes, incase you haven't already found out, the inverter that you have has thermally controlled fans, that is that they won't come on unless the unit is getting warm.
A Jaycar employee
SOURCE: clio inhibitor switch
Sounds likely. By not start you mean not crank right? when no go hold key in start posision & bump gear shift up to top (park) if start = inhibitor (Some are adjustable)
Try unplugging the refrigerator for 10 minutes again and see if it resets that alarm system. Its possible that the power surge damaged the electronics when the power came back on after the failure. Power failures are not good for any appliance or electronic device because the voltage is sometimes very high when power is restored.
