SOURCE: Mr Coffee
Hi Guest,
Thanks for the solution, I already threw it out and bought a cheap coffee maker. Mine was over a year old-no warranty. :(
SOURCE: set brew delay
Assuming you're talking about the FT series with the "delay brew" button and the 24 hour analog as opposed to digital clock, it's simple.
First, you have to have your correct time set. This is simple just press the hour button and then the minute button until the correct time is showing. Be sure to look for the AM PM indicator to make sure you're getting the desired time set.
Then press the delay brew button and use the same hour and minute buttons until you get the desired time (again watch for am/pm)
That's it.
SOURCE: delay brew will no longer work.
electronics and steam do not mix mr coffee used to put the control boards under the front where it was warm and dry . now there right where the steam can ruin them ... you might try unpluging it and puting it in the sunlight for a day and see if it drys out another thing go to amazon find your model and make a review , this will help others not to make the same mistake you did BTW just so you know , you dont have a real mr coffee , sunbeam bought them a few years back and now its just china junk .... good luck ......please rate this answer if it helped, 3 or 4 stars .and keep me in the paid department . a 1 or 2 will knock me off the air . thanks
SOURCE: clean light won't go out, can't use delay brew feature.
Try unplugging it for several minuets & see if it clears it..
SOURCE: my mr. coffee coffee pot won't brew. it will make
Try running a cupfull of vinegar through it followed by a pot of plain water.This will remove any hard water deposits which may be blocking the tubes.
