Many noma timers and instructions appear on following links
http://waterheatertimer.org/Woods-timers-and-manuals-old.html
http://waterheatertimer.org/How-to-set-timers.html
SOURCE: lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
SOURCE: i have noma timer N1502 lost instructions help
This timer goes on at dusk automatically. You just push the button as many times as necessary until you get to the number which represents the hours you want it to remain on.
SOURCE: I have Noma outdoor timer
Page showing UPM timers including ET525C outdoor.
http://waterheatertimer.org/UPM-timers-and-manuals.html
Manual for ET525C
http://waterheatertimer.org/pdf/UPM-ET525C-heavy-duty.pdf
SOURCE: Noma Timer Model #ET525C - Require Instructions
ET525C is UPM timer
UPM ET525C Manual
Instructions are 14 pages. It is impractical to re-write 14 pages of instructions.
If you have a problem, add a comment and say exactly which programming you want to set, and I will respond.
-Timer can be programmed for ON and OFF times, for Dawn-Dusk, for Countdown, for Daylight countdown, for daylight saving, and for Random. Each different programming option has 8-12 steps shown in manual.
SOURCE: i need instructions for noma
You can get the manual on the link below.
http://www.manualsonline.com/mdownloads/2ed87693-55db-443c-af0d-30a5ebb38b92.pdf
Good Luck
