SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: minolta bizhub erorr codeco202
CO202 relates to tray 1 (top tray). It hasn't managed to lift the paper successfully.
Open the tray, remove the paper, reset the machine (open/shut front door) then reload the paper and try again
Hope that helps
Regards
Taminol
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
