I have tried a puller and hit the shaft but can not budge it
Hi!
We can help. Check out our help centre to diagnoses the problem and find the answer. https://www.generatorguru.com/need-help/
If you need more advice we can get you in contact with one of our Generator Engineers to guide you. We do not charge for this service and are happy to assist you throughout the repair.
Kind regards
The Generator Guru Team
Specialist Portable Generator Engineers & Parts Worldwide
www.GeneratorGuru.com
SOURCE: how do you remove a flywheel, 24-025-04-S, without a flywheel puller
support engine weight below flywheel, with a center punch tap crank, after soaking with a penetrating oil.
Testimonial: "I just did the right thing and found a flywheel puller. Thanks for the suggestions. much appreciated! Brian"
It was pretty hard to get a flywheel puller on there wasnt it?
Use a brass hammer and a large flathead screwdriver. being carefull not to pry on anything but the crankcase and flywheel insert the screwdriver under the flywheel. With the hammer tap on the short cooling fins (These are tougher than the longer ones- you dont want to break off any fins) while prying up on the flywheel with the screwdriver. A few taps and it should pop loose. It doesnt require a lot of force but you need to be decisive with your blows.
SOURCE: I cannot remove the magneto cover from around the
I am having the same problem and i have tried pulleng too
