Vacuums Logo
R
Raewyn Dawe Posted on Dec 26, 2018
Where would I find a Reinhold aqua jet user manual. I need to know how to attach the brush
3answers
I have the shark rotator vacuum and the brushes won't spin
Hello again Lois Victor,
Make and model number always help... Thanks.
If you don't have your manual...
find them FREE at
Shark NV750ANZ Owner Manual
or here..
Shark Rotator NV752 Owner Manual
or by going to
http://poweredliftaway.com/
AGAIN... hope this helps
Carnac the Magnificent
How does Aqua Mate attach to Rainbow SE vacuum?
You can download the manual here...
Rainbow Vacuum Manuals
We are also available if needed at Contact Us
RainVac
1helpful
Need Manual for Milex Aqua Magic 1800w vacuume and shampooer
go to the vacuum sight just type the brand and then .com and it will take you right to the sight and then type the model number it the website search bar and go to the users manual and then download it for free
Mar 24, 2014 • Vacuums
I do not understand how to use the upholstery
Please reference this user manual, starting with Page #11. I believe it will guide you thru it.
http://www.hoover.com/pdfs/manuals/F5891900.pdf
I have my vacuum set to shampoo a rug, but cannot get the water to come out
Sometimes it takes up to 10 or so minutes for the Aqua mate 2 to begin pumping out anything.
If it is the new Aqua mate 12 (the big blue one, that is like a giant power head) the same thing is true for it.
If it is an earlier model Aquamate, then it is clogged somewhere in the hose, or the fluid control valve is clogged.
The water separator is the thing that spins in the center of the motor where your water basin attaches to it. It looks like a cone shaped fan looking thing. It should be cleaned after every use.
Use your Rainbow separator cleaning brush, or a tooth brush, if you do not have the Rainbow one. They are just like tooth brushes.
Never store your Rainbow canister on your water basin, with or without water in it. It can and will ruin your vacuum in dew time.
You can get manuals either here,
http://www.rainbowsystem.com/ or here,
http://www.rainvac.com
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Brush Bars won't turn
I borrowed a bissell 9500. It was filthy with the previous user's debris, including long and short black hairs, black goo from the swamps of hell, cat hair and dirt. I cleaned the whole machine (as mentioned in the online user's manual), pre-spotted my carpets, filled the appropriate fluid containers, and confidently turned power on to the 9500. The BRUSHES DIDN'T WORK ! After checking all belts, and other things mentioned in other solutions here on Fixya, I decided to check the trigger setup on the handle part of the cleaner. I unscrewed all the screws from the top of the handle down to the attachment holder ( there were seven screws). After that, I gently pried open the top portion of the handle in order to see down to the trigger. I gently pulled the trigger and, at the same time, repositioned it and the spring attached to it. Then, I put the screws back in, attached the power cord, turned on the power, released the handle's upright lock. When I did that, the brushes turned like they are supposed to. At that point, I felt like I'd awoken from a nightmare and, at the same time, been blessed by an unseen cosmic power. The rest is history. My carpets and upholstery are now as clean as when they were new. I hope this helps one or more of you out there with the "dead brushes" problem.
A solution submitted by:
Pierre Kunde
[email protected]
1helpful
Rainbow Aquamate 2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=620181
Rainbow Aqua mate 2 (by 3 users)
Posted by nicks mom on May 24, 2008
I cannot get water to come out of the water basin in order to shampoo. It is all connected correctlyXThis Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
2 Other Users Have the Same Problem Comment by deucedown, posted on May 26, 2008 Same problem here, I have only used the shampooer twice and water will not come out of the basin. I need to shampoo my carpets today and this is very discouraging. Somebody please help. I hooked it up and followed the directions. Comment by Angela31, posted on May 26, 2008 We are having the same problem. Everything is connected and no water is coming out. We have only used our Aqua mate 3 other times. Please help. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum / Aqua Mate. It has been a long time since I have operated a Rainbow Aqua Mate so I suggest that The best solution to operate the Rainbow Aqua Mate is to contact the Rainbow Tech Support line listed below or to contact your local vacuum cleaner dealer and have them send out a Rainbow Aqua Mate owner’s manual so that you can operate the unit successfully. By listening to the 3 questions listed above the actual water basin I believe is the recovery water tank to be emptied when full and I believe that there is a separately bottle or tank that the solution goes in order to dispense the water.
If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
1helpful
3answers
I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
Kirby G5 Bagged Upright Vacuum
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
4answers
Bosch vacuum
check the belt, it might be stretched or broken
or carpet fibers and hairs may have clogged up the brushes to keep them from rotating
let me know if this isn't the problem
Top Jet Vacuums Experts
john h
Are you a Jet Vacuum Expert? Answer questions, earn points and help others
