Question about Jensen Car Audio & Video
I bought a used Jensen vx6020 with no remote and no GPS antenna. It's installed correctly but I have no sound to the speakers. Navigation doesn't come on either
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 61 Answers
Double check the fuses to the unit then double check the ones specifically for the radio as well as the ones under the hood then re check ALL connections to and from the radio..
Posted on Dec 26, 2018
SOURCE:
  • 13433 Answers
SOURCE: navigation fatal error Error 1706
Heres what microsoft says about 1603
http://support.microsoft.com/default.aspx?scid=kb;en-us;834484
CAUSE loadTOCNode(1, 'cause'); You may receive this error message if any one of the following conditions is true: • The folder that you are trying to install the Windows Installer package to is encrypted. • The drive that contains the folder that you are trying to install the Windows Installer package to is accessed as a substitute drive. • The SYSTEM account does not have Full Control permissions on the folder that you are trying to install the Windows Installer package to. You notice the error message because the Windows Installer service uses the SYSTEM account to install software.
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this problem, do any one of the following, depending on the cause of the problem: • Install the package to a folder that is not encrypted.
Use this method if you receive the error message because you try to install the Windows Installer package to a folder that is encrypted. • Install the package to a drive that is not accessed as a substitute drive.
Use this method if you receive the error message because the drive that contains the folder that you try to install the Windows Installer package to is accessed as a substitute drive. • Grant Full Control permissions to the SYSTEM account. (for Windows 2000 and Windows XP only)
Use this method if you receive the error message because the SYSTEM account does not have Full Control permissions on the folder that you try to install the Windows Installer package to.
To grant Full Control permissions to the SYSTEM account, follow these steps: 1. On the Windows desktop, double-click My Computer. The My Computer window appears. 2. Right-click the drive that you want to install the Windows Installer package to, and then click Properties. 3. Click the Security tab. 4. On the Security tab, do the following: • If you are using Microsoft Windows 2000, verify that the Name box contains the SYSTEM user account. • If you are using Microsoft Windows XP, verify that the Group or user names box contains the SYSTEM user account.If the SYSTEM user account does not appear in the box, follow these steps to add the SYSTEM account to the box: a. Click Add. The Select Users or Groups dialog box appears. b. In the Name field, click SYSTEM, and then click Add. c. Click OK. 5. In the Permissions section, click to select the Full Control check box under Allow, and then click Advanced. 6. Do the following: • If you are using Windows XP, in the dialog box that appears, click to select the Replace permission entries on all child objects with entries shown here that apply to child objects check box for the SYSTEM account, and then click OK. • If you are not using Windows XP, in the dialog box that appears, click to select the Reset permissions on all child objects and enable propagation of inheritable permissions check box for the SYSTEM account, and then click OK.Note If you receive a security message, click Yes. 7. Wait for the operating system to apply the permissions that you have selected to all child folders. 8. Run the Windows Installer package.
Posted on Mar 09, 2008
IB4G2008
  • 3587 Answers
SOURCE: Navigation fatal error Error 1706
yes..I saw that..need teh model number of the actual gps you are using, please..
  • 47 Answers
SOURCE: hELP ME!!!!!
IT CANT BE DONE THE SOFTWARE IN THE RADIO IS NOT COMPATIBLE SORRY
Posted on May 13, 2008
SOURCE: jensen vm 9412
I put a cd cleaner no liquid on it just brushes but it was playing the cleaner and then it froz now when i put in any disc it just says bad disc the radio plays fine what can i do
Posted on May 29, 2008
  • 43 Answers
SOURCE: GPS antenna
If your old antena is a Seatalk or NMEA antena you can use it for your C80
If you GPS antenna is older than five year change it.
Posted on Oct 31, 2009
Navigation sysyem in dash
this would be aftermarket installation. with the right head unit, speakers and amps, this should be fine. of course, the gps antenna needs to be installed where it has a clear view of the sky, otherwise, your nav syste, will fail.
Jun 01, 2014 | Ford Explorer Cars & Trucks
GPS antenna error
Unfortunately I have now solution. But since misery love company, take comfort that I'm experiencing exactly the same problem, even after the software update.
Feb 01, 2014 | JVC KW-NT700 7-inch Navigation Receiver...
No Sound from Jensen VM9725BT
Jimmie Monica Hey, Its not a problem with the unit. You have the blue or Blue/White wire hooked up wrong. Disconnect both the blue wire and the blue and white wire and I guarantee the sound starts working on everything. If you have one of those two wires hooked up for a power antenna or remote amp turn on, then switch which one you are using and that will fix the problem permanently. Disconnecting them both will get it to work though. I guarantee it. Please post back and let me know if it works for you. Thanks
Sep 06, 2013
Feb 22, 2013 | Jensen VM9725BT Navigation receiver
My Jensen VW9424 Navi unit doesn't keep the correct time. The unit displayed a time 30 minutes ahead of the correct time after installation. Several attempts have been made to set the correct time;...
you have to turn off the gps time there is a setting in the menu that you turn off navigation sync or something like that. Go to setup and nav time. It is whatever setting has to do with navigation time
May 25, 2011 | Jensen VM9424 Car Video Player
I want to update my GPS
You need to navigate to the Horizon Navigation Online Shop (see Resources for the appropriate download page). Click on the Jensen manufacturer link located on the left menu pane. Choose your particular Jensen GPS model from the menu selection.
Choose the coverage area you wish to update your GPS unit with and choose to download the map updating software or have the software sent to you through the mail in DVD form. Fill out the order form information including your payment method (Visa, MasterCard or American Express are the only payment methods accepted). When you receive the updated software by either download or mail, install the software on your computer.
Follow the instruction prompts provided by the Navmate utility program with regard to updating your particular Jensen GPS unit's map software.
Hope helps.
Oct 07, 2010 | Jensen GPS
Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Apr 27, 2008 | Jensen A300HLX Car Audio Amplifier
Car Audio & Video Logo
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
