Korg Pa800 Synthesizer Logo
Posted on Aug 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pcm ram problem for korg pa800
Pls when can find the pcm ram 64mb for korg pa800 i called the korg company & they told that they dont have it by itself and i tried 64mb laptop ram but it dosnt work too can anybdy pls tell me what kind of ram's it fits instead of the original ram ? with great thanks for helpers sorry for my bad english
  • Anonymous Mar 17, 2014
    how i can fix it
Michial Gueffroy
Level 3:
President:
  • Master 1,140 Answers
  • Posted on Aug 06, 2009
Michial Gueffroy
Master
Level 3:
President:
Answers
1140
Questions
0
Helped
532406
Points
2214
Http://www.musitronics.org/ Try here but apparently they are on holidays until August 16. There is also an ongoing discussion athttp://www.korgforums.com/forum/phpBB2/viewtopic.php?t=44624 Hope this helps.
Korg pa800 256mb styles set
I wouldn't recommend doing that, because your OS system could freeze occasionally
2answers
Hello, I have a big problem with my korg pa800.i was install os 2.02 my sample ram have been disappaired when i have os 1.01 the sample ram was working.. but when i upate the os 2.02 sample was not saving...
After updating the firmware, you likely must do a factory reset. This is probably required so the keyboard will read and decide how much ram actually exists. At this site do the "factory reset" version:
http://www.korgpa.com/pa_root/en/products/pa800_soft.html
1helpful
Hallo, I have a Korg pa800 and whenevery I want to load DrumKit or a Sound from another set, I get a warning message (Load Sound Fails: not enought memory fro PCM samples). What should I do to load...
you may have to dump somethings from the memory, the memory is finite and if there is no more room there is no more room. as far as I know there is no expansion memory for this keyboard
WHAT KIND OF PCM RAM MEMORY IS USED IN KORG PA800 KEYBOARD.
Here is a site IF you are having problem with the PCM RAM. It sounds like you might even get a free replacemnet part.
http://www.korgpa.com/pa_root/en/products/pa800_faq.html
21helpful
4answers
Korg PA800. Ram Upgrade
The pa800 has a fixed amount of Ram at 64mbs and it is not physically possible to upgrade the Ram. The pa2x has a removable128mbs Module and that can be upgraded via a 256mb Module from Korg.
Keith [mrniceneasy - KorgForums]
3helpful
2answers
I have noise on ram samples
Korg Pa800 Synthesizer i have noise on ram samples Answer i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion,... (More) i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion, that happened 2 or 3 times, now its normal, but i think it may hapen again??? where is the problem, somebody says it is on motherboard? or its just ram overheating? since i install 2.01 os i noticed that its kinda warm in right display corner, can u help me???
1helpful
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
