Question about Bulova Watches
How do I set day and date on bulova 97C106 - Bulova Watches
    Top Expert:
  • Bulova Master
  • 52,799 Answers
Google (Bulova)(97C106)(manual) without parens for instructions.
Posted on Dec 25, 2018
SOURCE:
  • 580 Answers
SOURCE: How do I set the date on an old bulova caravelle men's watch
Pull the stem out 2 clicks the in 1 click turn stem clockwise for day and counter-clockwise for month. to set time pull stem out again 1 click, when finish push in 2 clicks
Posted on Jul 09, 2009
Cool_dud 09
  • 206 Answers
SOURCE: Day, date and time for a Bulova TFX watch
Step 1. When the second hand re a ches 12 o ’ clock (the zero or 60th second mark ) , pull the crown all the way to the “OUT ”position (you will hear two “ cl i ck s ” ) .All hands will stop.
Step 2. Turn the crown to move hands FORWARD (clockwise) until you see the date (for date only) or both day and date change.This establishes midnight, t h e b e ginning of the day.
Step 3. For A.M .time, continue to move hands forward until the minute hand is approxim a t e ly 5 minutes beyond the desired minute marker ;then ,gently turn b a ck to the same marke r. For P. M .time , follow the same procedure ,but first a dvance  the hands past 12 o’clock .
N O T E : The date will advance automatically at midnight, p rovided that A . M .a n d P. M .h ave been established (Steps 2 and 3).The watch calendar is pro grammed for a 31-day cycle.The  refore ,on the fi rst day of any month fo l l owing a month with fewer than 31 day s , the date must be advanced manually (see Step 5).
Step 4. When the time standard by which you are setting your wa t ch ( e.g.,telephone beep) re a ches the 60th second, push the crown all the way to the “ I N ”position . All hands will start instantly.
Step 5. Pull the crown to the “ I N T E R M E D I AT E ”position (one “ cl i ck ” ) . Your watch will continue to tell time. S l ow ly turn crown one way until the correct date a p p e a rs .Then for day/date models, s l ow ly turn crown the other way until the correct day appears .
N O T E : The day is printed in two successive positions on the day indicator: i n English and in Spanish on U. S .m o d e l s ; in English and in Fre n ch on Canadian mode l s It is possible to make use of either position. The display will automatically re m a i n in the language ch o s e n .
The date should never be ch a n ged manu a l ly between 9:00 P. M . and 3:00 A . M .a s this might affect the calendar mechanism and the accuracy of the date. ( Theme chanism will not be damaged if the crown is turned accidentally during this
time peri o d ,howeve r. )
Hope it helped U!
Posted on Jul 30, 2009
SOURCE: date set
The winding stem of the caravelle has two positions when pulled outward from the case. Pulling it full out lets you set the time. And, by rotating the hands through successive twenty-four hour periods it resets the day of the week. Pulling the stem halfway out allows you to set the month, but only if you rotate the stem in a counterclockwise direction..
Posted on Oct 03, 2009
tjaipuria
  • 77 Answers
SOURCE: how to quick set date on n5 accuquarz bulova watch
Hi friend i am providing a link I hope this will help you out.
http://reviews.ebay.com/How-to-set-day-date-on-Bulova-Accutron-2182-movement_W0QQugidZ10000000006982861
Gud luck.
Posted on Oct 06, 2009
  • 8404 Answers
SOURCE: where can I buy a dial window for my bulova super seville
You can probably buy one at the jewlery store. Problem will be that you cant put it in unless you have the special tool to do it.
Posted on Feb 05, 2010
I just bought a Bulova Super Seville watch how do you set the day and date?
Pull the stem out one click, rotate stem clockwise to set day, counter clockwise to set day, pull stem out to second click to set time
Feb 22, 2011 | Bulova Men's Watch
Westclox model LTX271 instructions for setting day
mcdevito75 here, The stem on your westclox has 2 positions, First pull the stem out to set the time of day, keep cycleing the watch until you come to 1 day before the day you want. NOW! push the stem back in. NOW! slip a finger nail just under the crown and gently, gently kift the crown to it"s first position, it may take a little practice so be patient, once in it's first position you can change the DATE easily, change the DATE to 1 DATE before the DA you want, push the syem back in and pull the stem back out and set the day/date and time of day. Your watch is set and will change on time a little past mid nite.
Jul 22, 2010 | Bulova Watch
GB743 CHANGE DATE
mcdevito75 here, Your Bulova watch should have a 2 position crown (winder), carefully lift the crown to it"s first position, this should allow you to change the DAY, once done pull crown out to set the time, keep turning the hans till you get the right DATE (number) now set the correct time and your done.
Jul 01, 2010 | Bulova Watch
How do I set the day on a Cote d' Azur watch I purchased on a Royal Carribbean Cruise
Are you shure you CAN set the date? Most of these watches are fake. I got one at a NCL cruise. For its price, it's fake. So it is not fully functionally. It only shows the time. The date mark is not real on my watch
Apr 27, 2010 | Bulova Watch
How to quick set date on n5 accuquarz bulova watch [this watch has date only]
Gud luck.
Oct 06, 2009 | Watches
Date set
Oct 03, 2009 | Caravell Bulova Caravelle watch
Can't set the date or the day
the date was on the31st of in a 30 day month, I advanced the hands of the watch till it advanced the day to the 1st of next month it usually advances to the next day about 1:00 am, and date both the date and the day will advance together
Sep 30, 2009 | Bulova Watch
Jul 09, 2009 | Bulova Watch
Watches Logo
237 people viewed this question
Top Bulova Watches Experts
Arturs Kalnins
Arturs Kalnins
Anthony Ward
Anthony Ward
Are you a Bulova Watch Expert? Answer questions, earn points and help others
