Question about Samsung Audio Players & Recorders
My Samsung UE55HU7505T TV and harmon/kardon Go + Play Wireless speaker work perfect. But the TV Connected to harmon/kardon Citation 500 creates sound delays. How can I solve this problem?
SOURCE:
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
SOURCE: harmon kardon avr 25 II
hey i also had this problem, i don't know the name of these but they are basically plugs that you have to block output from the front rear and center speakers of the white/red cables... sry for bad description but its on the left side when looking at the back of the receiver, while all of the other speaker wires should be hooked up to the right with the twisting knobs... it took me forever to find this out but yeah it was a simple fix
Posted on Oct 30, 2007
Open SKy
  • 620 Answers
SOURCE: Harmon Kardon Sound Sticks
Hello there
First things First:
1) check cables, and the input cable to your PC.
2) Check for right voltage, may be somethings is chargind a lot**
3) Power regulator on the Speakers is damage.
4) RMS your Spks, for replace. or warranty.
5) try in another computer. ( if apply)
Posted on Jan 26, 2008
  • 440 Answers
SOURCE: hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Posted on Feb 11, 2008
renosean
  • 492 Answers
SOURCE: humming noise
Usually Humming noises come from frequency interferance.  In this case it is being caused by your input sources.  A smiply solution is to replace the cables and or seperate the source cables away from any electircal cords or sources.
Posted on Jan 07, 2009
Esquire Wireless shuts off during play
Think I might just have discovered the issue here. I had the same problem but didn't realize that the volume was maxed on the unit (as I was controlling it through the phone). As soon I brought the volume down on the unit the problem went away.
Apr 13, 2014 | Harman Kardon Audio Players & Recorders
Trying to connect samsung smart tv to harmon kardon avr 330 with toslink cable, but i'm not gettting any sound through the receiver to speakers
The inputs may be assignable on the Harman Kardon. Make sure you have selected the proper analog or digital input type for the cable you are using. For more information, or should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Dec 14, 2013 | Harmon Kardon Harman Kardon Avr 330 5.1...
Harmon Kardon Go+Play speakers wont work on Del laptop with Windows 7.
click start control panel hardware and sound manage audio devices playback
you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties
you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality windows7
hope this helps
Feb 16, 2012 | Harman Kardon Audio Players & Recorders
My Harmon Kardon AVR 500 sound doesn't work, I disconnected speakers, re connected & reset protection. Nos ound not even on test mode
Hi it is seem there is no output from your device. Please check the circuit components and wires for malfunction in your Kardon then. Regards
Feb 09, 2011 | Harman Kardon AVR 500 Receiver
Getting buzzing sound from speaker but can here sound from them.
You could have an earth loop which causes a hum/buzzing sound.
Is your computer and powered speakers plugged into different mains?
Connecting amplifiers and speakers to different power sockets will create earth loop problems
This can be fixed by using a single power board connected to a single mains power socket, then connecting all the computer components and powered speakers into this one power board.
Oct 31, 2009 | Harman Kardon Harmon Kardon SoundStick II...
Will not play sound from the internet
my computer will not play a sound from the intrnet
Sep 28, 2009 | Harman Kardon HK206 Computer Speakers
No audio from my Harmon Kardon SoundSticks II
mute the inbuilt speakers you can hear the sound from the external speaker
Mar 22, 2009 | Audio Players & Recorders
Need a replacement power cord for harmon kardon sound sticks II
its not that expensive for a power cord. they are running on 12v so you go and buy a 12v power supply with a jack that fits the speakers or you can just find a power supply at home if you have one that is 12v
Jan 05, 2009 | Audio Players & Recorders
Hooking up an amp
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
