Computers & Internet Logo
William Gates Posted on Dec 25, 2018
How to connect a Tzumi wireless mouse to HP Stream 14
1 Related Answer
unvme
Harold Case Jr.
  • 266 Answers
  • Posted on Dec 27, 2010
SOURCE: wireless mouse won't connect
press the connect buttons on the mouse and the reciever
2answers
How do I get my wireless HP mouse to work?
Hope that the videos help. Good luck.
I upgraded my HP Stream pro 11, and now my touch pad is unresponsive
upgrade what?
from what to what. w7 to 10? what?
seems w8.1 to w10? came with both new, {OPTIONAL
what stream there are 18 models of stream.
i cant guess them at all , must be said.
there are 4 , Pro 11's in fact.
ever heard of HP.com? the company
they made it and the support page is here.
for touch pad for sure, called input devices on the software page.
ill do wild guessing, lacking your service tag data.
example, w10 64bit now.
https://support.hp.com/us-en/product/HP-Stream-14-Pro-Notebook-PC/15932849/model/15932850
are you internet connected?
be so
then in device manager. (CP)
click on the mouse pad driver there and click update driver yet?
if that fails
you need to load HP drivers, to make it work.
or just run the HP support assistant.??
http://h18021.www1.hp.com/helpandsupport/hp-self-support.html
Why is wired Tzumi not working with Motorola?
Molly-
I would contact Camera 360 and Tzumi Wired remote developer to find out what the requirements are for the wired remote to work.
Once we know the requirements we should be able to find out if your Droid X2 has the capability.to use the wired remote.
Mark
Motorola Support
1helpful
2answers
My wireless mouse has quit working. I'm guessing I need a new battery. However, I can't figure out how to even find the battery, let alone change it! How do I do that????
Cutting down on the number of wires that must be tolerated in a work station adds to maneuverability and ease of location. For all their convenience, though, wireless accessories bring with them a number of issues not present in their wired counterparts, most significantly battery change.
Instructions
    • 1 Turn off the mouse.
    • 2 Remove the top of the top of the battery compartment. The button that releases it is located toward the rear of the mouse.
    • 3 Remove the old battery and place the new one in its place. Replace the cover and turn the mouse back on.
Read more: How to Replace the Batteries in an HP Wireless Mouse ' eHow.com http://www.ehow.com/how_6947071_replace-batteries-hp-wireless-mouse.html#ixzz1LpG7oNYf
2answers
I have a samsung np-nf110/nf210/nf310 , os is windows 7 starter. i wanted to use my HP wireless optical mobile mouse but it doesn't seem to work or i dont think it connected. batteries are brand new and...
we dont do Samsung here, its HP
but HP mouse with no model stated, is impossible to be accentuate.
its a wireless mouse right, you left only small hint.
battery powered wireless mouse ,.by HP
windows 7
wireless mouse, HP and Samsung.
that takes 2 working drivers to make that work. both HP
the USB side and the mouse side.
HP does not support this on non HP computers so windows 7 is the only hope, MICROSOFT PLUG AN PLAY
you must be connected to the internet or its all just a wasted of time,
do so.
then plug both those things in.
the PC goes Dingdog sound telling you its found a new USB device.called wireless mouse HP, (no model stated)
then tries to find a driver on the web, MS servers for that.
if it can find one, then good luck, doing that. as the HP drivers will not like your PC
as here, if this is possible at all.
https://h30434.www3.hp.com/
4helpful
2answers
Wireless mouse won't connect hp wireless optical mobile mouse
1helpful
3answers
Wireless mouse not working
Mabey its old try new battiers and the reciever in a new usb port
Hp wireless mouse not working
HP wireless mouse may not work due to improper connection of the receiver. If unknowingly you connect the receiver to a different port, then it may cause serious issue with HP wireless mouse.
If the connected port is corrupt and if the port is experiencing any problem, then the wireless mouse may not work properly.
In order to resolve this issue, you need to repair the port.
Get more information to fix HP Wireless Mouse Not Working . Hope this information helps you.
Grand Canyon Tech
Grand Canyon Tech
