My washing machine won't start at all. I've checked all the outlets and fuses. Everything else works fine. Why won't the washing machine start?
Changes are you broke a "drive belt".
It snapped causing the noise.
Lift the top up (easy if you pry a bit on each corner).
You will see the broken belt.
Remove the old belt and take it to a shop to make sure you get an exact replacement.
Threading the new belt can be a tiny bit confusing but it will soon become obvious.
It is like the "fan belt" in a car.
SOURCE: Fisher and Paykel Pride 5.5kg
My washing machine will not cut off on a high water level, but will on the medium. It will wash until it gets to the short wash and then it just beeps at me. I tried to advance it to the rinse cycle but the light just blinks and won't do anything more. It did drain the water out though. What's the problem and how do I fix it.
SOURCE: My washing stopped working mid cycle. I checked
the timer is probably sticking (needs replacement) or lid safety switch stuck open. try restarting the load and if stops at the same place it is the timer unit, if it fills up with water and than stops - lid switch.
SOURCE: My Kenmore Calypso washing machine has is
Where the power cord goes into the washer is a small box called a line filter. It is there to protect the electronics in the control. It might be that the line voltage filter has failed. Remove the rear panel on the control to access it. Calypso Service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: my car was running fine yesterday and this morning
Check for spark and fuel. When you turn the key on you should hear the fuel pump in the tank for a few seconds till the pressure builds up. When you crank the engine there should be spark at the plugs.
