When my outboard engine is running it appears to be outputting 15.9 volts. The inverter shows low battery
Check your connections. 750W is about 7 amp at 110 V. It's going to try to draw 80 amps from the battery! Recommend you check voltage with a multi-meter - I made up a set of probes for my meter with needle points so I can go right through the insulation of the wire and check voltages. Looked at an on-line photo of the unit, and the clips (and wires) look light for carrying 80 amps.
SOURCE: 1909 buick skylark tps low volts trouble code
replace ignition coil make sure by dealer the right mode is used when ordering if not ordered right you will get a difference in engine volts
SOURCE: 1998 cadillac catera new batteries die, voltage meter reads low
you want me to pay you for help, and you want me to tell you how I fixed the problem without you paying me! ! ! ! Huh, something doesn't seem right here. How about you pay me to tell you how I fixed the problem!!!
SOURCE: 1962 CHEVROLET TRUCK with points
If/How long will it crank over before it stops? Are you saying it will crank over, but very slow? Has it been sitting quite a while. Got good spark, and fuel?
SOURCE: I have a 1996 Isuzu
This may be caused by a bad Voltage Regulator in the alternator. It is quite possible that you have a faulty alternator. It seems that the regulator may be going in and out. I would have the alternator tested.
The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
