Question about Frigidaire Ovens
Why did my Frigidaire oven lock and go to self cleaning when baking
    New Friend:
  • 128 Answers
Possibly you accidentally pressed clean button
Posted on Dec 24, 2018
    Top Expert:
  • Frigidaire Master
  • 64,317 Answers
NO CLUE HERE BUT POSSIBLY THE CONTROL BOARD FAILED ON IT
6ya staff
SOURCE:
robert samples
  • 1314 Answers
SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Posted on Jun 05, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
Posted on Dec 09, 2008
Paulo
  • 188 Answers
SOURCE: Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Posted on Apr 03, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Frigidaire oven won't lock door for self cleaning
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Posted on Apr 18, 2010
asalvekar
SOURCE: after self cleaning ge oven, door won't unlock
I turned off circuit breaker to the oven and tried to open it. It did not. I did it again and waited for a few minutes, it worked and I was able to open the door.
Posted on Aug 10, 2010
My frigidaire oven door says locked and I cannot unlock it.
Reset the unit at the household circuit breaker for about 10-15 minutes. Then retry the unit. If no changes occur contact a professional technician, sounds like the door latch and/or control board need repairs.
Aug 02, 2012 | Frigidaire Ovens
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidaire self cleanig oven and I want to clean it. I pushed the clean button and it lopcks the door but it does not get hot and act like it is cleaning. The oven is over 6 yrs old
These may be dumb questions... but do your bake and broil typically work correctly? What model do you have?
Depending on model, you should be able to press clean, high or low (2 or 3 hrs), then clean again. At that point the door should lock and the bake element should begin to get hot.
Aug 29, 2011 | Frigidaire Ovens
On Frigidaire Self-Cleaning Range, bottom oven element does not work while top element does; bake relay problem?
Sounds like the bake element is out. Remove it and test it for continuity. If you need further assistance please feel free to contact me.
Jul 09, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How do you operate oven
You should have a bake and broil button and arrows to adjust temp up and down. Of course a start button should be there. If no off button, then there should be a cancel button to turn it off. The door only locks in self clean mode.
May 21, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Door lock is on
Hold the lock button for 3-5 seconds or Find the main circuit breaker for your oven. Turn it off for fifteen minutes, then flip it back on. This should allow the door to open. Another thing sometimes, the dial for self clean will hang up, but this should fix it.goodluck hope this helps
Dec 22, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
How does self cleaning work on my frigidaire gas burner stove?
Self cleaning would be better named... Running the oven real hot to burn off residue.. so in essence, the oven is locked out and then heat is raised to a high level to bake out grease and food byproducts so they either burn off or turn to ash for easier cleaning.. Does that make sense to you? Most self cleaning ovens lock out the user until the oven has cooled down to a safe user-friendly level..
Nov 28, 2008 | Ovens
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Jun 02, 2008 | Frigidaire Ovens
Ovens Logo
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Ekse
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
