Car Audio & Video Logo
T
Thys Beukes Posted on Dec 23, 2018
Which wires to use for nakamishi na 3610 steering control connection
My horn isn't working on a Chevy equinox but it's a new horn. What could be wrong with it..and my cruise control don't qork. Is it my steering wheel?
Was Cruise Control working before the New Horn was installed? The power supply to the Horn, (input to ground wire) is connected to the Cruise Control Module (CCM). This CCM is wired to the Relay Switch Box located in the Engine Bay. The Relay Box cover will have a Chart indicating what function each Relay coresponds to. Your local autoparts store (AutoZone) can test the Relay Switch, and you'll know (if any Relay) need to be replaced.
The CCM is also wired to the Steering Wheel, but first passes through the Clock Spring Coil, located just behind the Steering Wheel. The Clock Spring allowes for the Function Buttons on the Steering Wheel to have power while Steering Wheel spins.
The Clock Spring can malfunction or break, its rare, but this will cut power to the Function Buttons on Steering Wheel. If ALL the buttons on Steering Wheel dont work, then the Clock Spring is the Culprit. The Coil may need to be replaced.
The Cruise Control Module itself may have failed and also would cause a few or all Steering Wheel Functions to quit working.
But first check the Relay Switch Box and examine the Harness Cables connecting (Steering Wheel--to--CCM--to--Relay Switch Box--to--Battery Supply).
Also if Cruise Control was working before the new Horn was installed and now not working, then most likely the Problem is a bad wire connection somewhere and/or is a faulty Relay.
(Any Questions/comments [email protected])
1helpful
How i can connect a Gemini cdm-3610 to a laptopand which cabes i can use
It depends on what connections the laptop has. Most have an audio in socket. So you can use that. All you need is to find a audio out on the deck. I looked at an illustration and it has an headphone socket. So you could use that. Just keep the volume control low.
Cruise control not working
You need to post the make and model of your car.
Generally if the cruise control light is on, on the dash indicator then the problem is in the steering wheel electrical connection.
Then internal wiring connecting the steering wheel cruise control switch is connected to the dash by a special wire called a clock-spring ribbon. This is located under/behind the steering wheel. It is not a self service repair item and required a good deal of expertise to repair. Sorry, but you will most likely need to take it to a qualified mechanic. Because the steering wheel also contains an airbag, do not attempt to do this repair yourself!!!
j
This is about the high pressure side hose from the power steering pump which has a sort of electric shut off. Dati nag leak at pinalitan ng bagong hose using the same valve. after 2 months, umingay na na...
First try to replace the Hi side hose w/ original one before u buy a PUMP assembly! U could buy cheaper part in Banawe, Young Bros. is the store, they could get u a replacement and original w/ discount!
4helpful
2answers
The horn and cruise control doesn't work,fuses are
sounds like a bad clockspring. located in steering column under steering wheel, operates airbag, horn cruise etc, it make wire connection possible so the wheel can spin, its a roll of flat wires, that unroll and roll up as steering wheel is truned from left to right,wires break after a while.
Resetting EnGenius EOC 3610
Dear Venmattey,
please follow these steps, it works:
1. Connect the EOC-3610 to your computer with a null modem serial cable.
2.Start a HyperTerminal session: Click Start and then select Programs-> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3610.
b. Select correct COM port. Ex:COM1.
c.Set baud rate as "38400", data bits "8", parity "none", stop bits "1",and flow control as "None". Then press “OK” to bring up theHyperTerminal window.
d. Unplug the power on the POE injector and wait 5 seconds then plug the power back in.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
NEW: Keenan Systems has written a software that will soft reset the 3610 series back to factory reset. Thisfree software is provided "AS IS" by Keenan Systems and is notsupported or guaranteed by EnGenius Technologies. Use at your own risk.
Be Happy Always
Regards
Daismantle of 3610
hi, first remove the LCD and its wiring, once the hinges are free u will figure it out..let me know
2answers
KVT-729 car DVD player
The steering remote control input is for a wired remote control, or a third-party interface that allows you to adapt vehicle steering wheel controls to operate your deck. Your problem is the parking sensor wire. This is supposed to be connected to your vehicle's parking brake switch. It detects when the brake is set, and will prevent a picture from showing when it's not set. The intent is to prevent you from watching movies while the vehicle is in motion. If you can get a good look at the parking brake mechanism, you should be able to see the brake switch. Usually there's a single wire coming from the switch, which is built onto the parking brake mechanism. Connect your parking sensor wire to the wire coming from this switch.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
