It sounds like something not put back correctly or adjusted. Was the slave cylinder arm push in when you bled the system? There may be air behind it. Did you use a pressure bleed system, slave up to Master. Lots of help in the links.
Popping could be the gears slipping, look for something that is jammed in the gears. It might be defective too, it could be stuck in going in one direction and not stopping, that would cause some noise. If it is new, take it back, and try another. If you get the same problem, read the manual before you use it.
1. Calibrate Drone
2. Calibrate Controller
3. Once airborne, have the drone rotate on its horizontal access (left stick, left or right) for a couple of turns to allow good communication with GPS satellites
If this is not a GPS issue, check all the rotor blades and replace any damaged ones, taking care to have them fully bedded down. Make sure you have put the white and the black onto the correct stalks - because they spin in different directions!
Check if drone is fully charge. LED lights needs less power than motors. Maybe that is why LED is glowing. If drone is fully charge, check if there is any unwanted material stuck near the blades which are creating extra fiction on the motors. If you are looking to buy another drone, here are some of the mini drone with camera that you can buy in less possible price. 11 Best Nano Mini Drones With Camera You Can Buy The Tech Toys
One drone that can reach a range of around 2000 meters is the DJI Mavic Air 2. With its OcuSync 2.0 transmission system, it offers a reliable connection and a maximum control range of up to 10 kilometers (approximately 6.2 miles), allowing for extended flight distances and exploration capabilities. You can check here dronesinsights
THE HARVEST CYCLE begins when the freeze algorithm (programmed into the
electronic control board) has been satisfied and the sensor arm is out
or fully extended. If the arm is in the “in” position when harvest is
to begin, a delay of 3 minutes will be added once the arm is moved to
the extended position to allow for drawer type ice buckets to be
removed for this amount of time without starting a harvest cycle. This
3 minute delay will begin again if the arm goes back to the “in”
position anytime during the delay period. This arm is spring loaded to
go to the “out” position unless it is being held in the “in” position
by an obstacle such as an ice cube.MORE
