Question about Necchi Sewing Machines
How to thread necchi 575FA correctly - Necchi Sewing Machines
  • Necchi Master
  • 9,131 Answers
Possibly shown in youtube videos.
Manual for sale:
https://www.sewingpartsonline.com/instruction-manual-necchi-575fa.aspx?
Posted on Dec 23, 2018
SOURCE:
SOURCE: I have a necchi model
if the sewing machine is not sewing & staying in one spot the that means the feed dogs are not working properly.
I also have a necchi sewing machine, check the needle plate area that's where the feed dogs are, if the feed dogs are up where you can see them & even feel them with you fingers when you rub your fingers over the needle plate area, if you can't see them good or feel them, then they are not up,,my instruction book shows that you have to remove the extension table, their should be a small door in front of the needle plate area to open that's where the feed dogs are if they are not in the up position, where you can sew, if they are in the down position move the lever to the opposite direction & see if that help the machine to sew, if it make makes no difference which position there in , then it's possible something is wrong with the feed dogs & the machine needs to be serviced
Posted on Sep 18, 2011
JeremySew
  • 65 Answers
SOURCE: need zipperfoot for necchi model 575fa -574fb
We have that presser foot available here:
Universal Low Shank Zipper Foot
Posted on May 22, 2009
  • 152 Answers
SOURCE: is a Necchi model 575FA any good? I would also
Necchi is imported by Allyn International, I think they're in Denver area.
Their phone number is: 1-800-525-9987
Posted on Oct 08, 2009
  • 255 Answers
SOURCE: I need a manual for a Necchi Royal Series,
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/4795_Instruction_Manual.htm
Happy Sewing!
Robbie
Posted on Mar 15, 2010
SOURCE: Necchi 215A Sewing machine Could anyone help I
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Posted on Sep 27, 2010
Testimonial: "Thanks for the answer it did not work for me though"
Necchi 575FA how to put the bobbin spool in the case?Bobbin mats up with a lot of threads on the bottom stich.
The problem most likely is not the bobbin. The problem is the top thread. If thread is knotting, tangling under the fabric, it is a top thread problem.
Remove the top thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning.
If there are still thread clumps under the fabric, you will need to increase the top tension. (The extra thread appearing under the fabric is excess top thread hanging up under the fabric.) You may need to keep adjusting the top tension until both top & bobbin threads meet in the middle of the fabric.
Mar 11, 2018 | Necchi Sewing Machines
How do I attach the buttonhole presser to my necchi 575fa
by removing the normal foot loosen the screw holding it on the put button foot in place of it and tighten the screw back up
Feb 22, 2015 | Necchi Sewing Machines
I have a Necchi 575FA and the bobbin thread cloggs up.
try changing the needle
also try using a different bobbin just incase there is something
wrong with that one
make sure the thread is wound evenly on the bobbin or this will
cause problems
make sure the bobbin is turned the right way in the bobbin case
Nov 29, 2012 | Necchi Sewing Machines
Is a Necchi model 575FA any good? I would also love any info on this company! Thanks!
Oct 05, 2009 | Necchi Sewing Machines
Instruction manual
the manual is not available for free download and Necchi does not provide manuals for discontinued models.
You can buy the manual download on this site for $10.
Regards.
Aug 29, 2008 | Necchi Sewing Machines
Sewing Machines Logo
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
