SOURCE: Transmission repairs
It sounds as if there is no oil pressure in the transmission, it is possible you have no fitted the convertor correctly. if it is not fully engaged into the transmission oil pump it will not drive. of course the other thing could be the transmission has a fault. I am of course assuming you have filled the transmission with the correct type and quantity of oil. if you have pull the trans, and check the convertor has not damaged the oil pump,
