SOURCE: Cannot open the dishwasher door. Maytag Quiet Ser...
This model has a problem where the handle must be depressed fully upwards to allow the latch to clear completely without straining the mechanism. The lip on which you pull open the door gives the operator a better handhold to force it open even when the mechanism is not fully depressed. Do this enough times, and the plastic tabs on the handle begin to fatigue and eventually break. The handle becomes lodged but can be forced down to eventually open the washer. By this time, a specific portion of the latch that depresses a micro-switch will most likely be broken, and the washer won't turn off if the door becomes ajar. Remove the torque screws along the inside perimeter of the door and you can spread the face panel open to access the latch unit for replacement.
SOURCE: I have a Maytag Dishwasher,
water pump out drain hose to sink kinked /stopped up if new disposol was installled and the installer did not take the dis/washer plug out it can not pump water to the drain
SOURCE: Dishwasher leaking from bottom of
Hi The issue is with the water not draining as something might
be blocking the drain pump assembly thus the water is leaking. To solve this
issue you'll have to take the front lower access panel out and then clean the
drain pump assembly completely, also clean the impeller and chopper assembly
located at the bottom of the unit. After this is done the issue should be
resolved, if not then check the float switch mechanism and make sure that is
fine. Hope this helps...please post back for further assistance. Daniel
