Hello, David -
Did you replace all 4 batteries? If not, Hokey Pokey Elmo takes 4 AA batteries:
https://service.mattel.com/instruction_sheets/B6678.pdf
If all 4 batteries are new, the problem may be with the circuit board or wiring.
This video of disassembling a Tickle Me Elmo may be instructive if you wish to open up your Hokey Pokey Elmo and check on the wiring and circuit board:
https://makezine.com/2016/04/08/tickle-me-elmo-how-about-dissect-modify-elmo/
I suspect Tickle Me Elmo and Hokey Pokey Elmo were built the same way.
More about Tickle Me Elmo (which may prove helpful with Hokey Pokey Elmo):
https://www.ifixit.com/Answers/View/368936/How+to+rewire+it+up
(Quote)
Sometimes there is just a broken wire in the box due to the vibrations made by the oscillator and or the batteries being removed and replaced activity. A blown circuit is rare unless someone tried to fix it and wired it wrong. It only takes a millisecond to blow a component if wired wrong. Same holds if a circuit gets wet ! Best advice is to remove the power source i.e. the batteries; and dry everything before turning it on !
The circuit itself is a small card. There are a few discrete components that are wired to the card. Check the connections. If you don't know exactly where the broken wire goes, don't guess ! It could be the end of Elmo as you knew him ! Get advice ! It could be the difference of a quick soldering and having to replace the entire unit. Don't be afraid of opening it up while just checking. Just put the screws back the way they came out.
Do it all with the batteries removed, please !
If the Device does nothing, it maybe the on/off switch. The batteries are obviously the first thing you checked, right?
If it talks; but, doesn't wiggle, its the oscillator connection.
If it wiggles but doesn't talk, it may just be the speaker wire.
If it talked but didn't wiggle and someone worked on it and now it does nothing, the person blew a component on the board. Most likely a capacitor. They don't take change in polarity very well ! The whole board is as cheap as the sum of its parts and labor.
(End quote)
If you get Hokey Pokey Elmo back to working properly, be sure to remove all 4 batteries when not in use and stored for a period of time, so that the batteries do not corrode and ruin Elmo.
Best wishes.
