Possible blockage in motor
SOURCE: shop vac
Vacuum is less than a year old and died in the middle of a use. No power... tried to plug it into 3 known, good outlets. Suggestions?
SOURCE: dewalt dc500 won't **** in water
there is a float ball or reed that closes off the exhaust port inside the canister, to prevent water from filling too high when used as awet vac. If lodged or trapped it will prevent suction or discharge in wet and dry modes. look at the housing that the filter attaches to and you will see it. if it doesnt rattle when you shake the unit up and down, it is stuck; otherwise, you must not be spinning the fan blades.
SOURCE: how can we avoid the odor that we usually have
Bagless vacuums have a real problem with bacterial growth. That is what produces the odor you are smelling. Wash the cup in an enzyme and the filters too if they are the washable type. Make sure everything is dry before you reassemble the vac. Then turn on the vac and pull the hose out like you would be using the tools. Holding the hose end that has the suction, spray a small burst of Lysol Spray into the hose opening so the vacuum "sucks" the Lysol through it's interior. This will kill the bacteria in the hose and the plastic housing of your vacuum. Usually 3 bursts works fine. If you spray too much and get your machine "wet" with the lysol you could damage your motor so small bursts are better than a long spraying action
SOURCE: How do I clean the foam filter in my central vac?
Simply hand rinse it, like you would a sponge. It's a good idea to have 2 filters, as this will allow the washed one plenty of time to dry.
