Buy HDMI adapter. https://www.walmart.com/c/kp/hdmi-adapters
Get a short HDMI cable extension, with a male connector on one end and a female connector on the other. Best Buy may offer them. There is also a very short HDMI adapter that allows up to 90 degree turn so the Roku will lie outward., also available at Best Buy or TV specialty stores. Finally, try using the HDMI side port on the TV's right side (to your left as you face it).
some flah drives need drivers . i think u r not using xp . the drivers can be downlaoded from the companys websit . can u ane the comapny
SOURCE: How can I connect external speakers to my Vizio VA26LHDTV10T?
Used the earphone plug with amplified speakers.
Testimonial: "That's my answer"
SOURCE: I cannot stick a hdmi chord in the hdmi port it is
Your computer may not actually have an HDMI port. The spot you are referring to is most likely where to manufacturer puts an HDMI output for higher model laptops.
SOURCE: My Vizio (VA26LHDTV10T) Tv says
You get this issue because the TV does not support the resolution your xbox is displaying at. I had the same problem with my PC since I use the TV as a monitor. The TV will do a max resolution of 1360x768 so, you need to set your xbox to that resolution or the one closest to it as long as it is under that number.
SOURCE: I am connecting Roku to an open HDMI port but I
In your TV, go to Menu, Settings and then turn on the HDMI port. Hope this helps Fix Ya up.
