I emptied the tray of old ice, reset the arm (down)...will not make ice cubes in the bin. Door ice is ok. I empty the old ice from time to time and never have a problem.
If your door has ice the ice maker is working. Something is blocking the ice from filling the bin inside. Look for obstructions including frozen water.
If you don't see anything, you could let the frig completely defrost with the door open. Its winter, put the food in bins outside. Any tubes or pathways would defrost if that is the problem. A hair dryer on the ice maker and filling tubes would speed things up.
Make sure the ice level sensor arm is moving.
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
SOURCE: tHE ICE MAKER IS NOT WORKING
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
SOURCE: I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
SOURCE: Icemaker makes ice, but will not dispense ice via door.
The auger arm in the back of the freezer should be rotating to test this hold the door switch in and push the dispise button down. If it does not even try it could be the control switch on the door. the auger motor is a 120v motor and relatively strong. You can test to see if you can manually turn the arm it should trurn stiffly. Its alsoi a chance you don't have the been in place correctly.
SOURCE: ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Yes, the inside dispenser is full of ice, works fine dispensing from the door. Could it be frozen inside? In the open part near the arm?
Send model #
Is there ice in ice maker that actually makes the ice ?
