SOURCE: power window motor driver door
I would not consider that issue normal. Camry window motors are quiet.
SOURCE: Mazda MPV V6 engine noise
My strong guess without looking at it would be a cracked exhaust manifold, when it gets hot the metal expands an it doesn't leak.
SOURCE: i changed oil in my 2001 izuzu rodeo and after it
Changing the oil is simple procedure.
it more sound like you left some thing close to a moving part.
Check over the engine very carefully. Around the belt area, by the fan.
Try to pin point the noise and add more information. Then I will try to gave you a better answer.
SOURCE: '96 Toyota 4-Runner makes a loud squealing noise and brake light
Sounds like one of the auxillary belts slipping it may just need tightening up. I think the 4-Runner has two belts one large and one for the steering pump
SOURCE: MAKING NOISE AT CENTER OF TOP ENGINE UNDER MANIFOLD LOUD NOISE
Is it a ticking or knocking noise? or does it sound like something is leaking could be a bad manifold gasket which would be better than a ticking or knocking.
