SOURCE: frigdaire gallery stove
lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
SOURCE: Beeping F11 error on Frigidaire
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
SOURCE: I have a professional series frigidaire stove and
Hi here is the meaning of the F30 error code. If you have any other questions please feel free to comment. Mike
F30
F31
Open probe connection.
Shorted Probe connection.
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Thank you for your inquiry, Katherine!
Based off the information you have provided your Frigidaire range is displaying an error code of "F11". An "F11" error code stands for a shorted keypad I would recommend performing a reset on your range. You can do that by flipping off the household circuit breaker for at least ten minutes. If that does not correct your issue it could be a possible problem with your EOC (Electronic Oven Control) or wiring harness. Hopefully this information is helpful for you. -Matt
