Question about Comcast XFINITY TV
Onn tv remote code for xfinity remote - Comcast XFINITY TV
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 56 Answers
Save hours of searching online or wasting money HELP NUMBER +1 833 837 6333on unnecessary repairs by talking to a 6YA Expert who can help you resolve this issue over the phone in a minute or two.
Posted on Jan 15, 2019
  • 5 Answers
SOURCE: just bought a ONN LCD TELIVISION MODEL AO37ZID from asda, looking for a 4 digit code for sky remote
Got this one to work on both the 37" AO37ZID and the smaller 17" Onn branded A017LC
Sky code: 0527
Posted on Nov 29, 2008
SOURCE: codes for my sons TV
Hi there i also had this problem with my "onn" television and there isnt an "onn" make - apparantly it is the same as pacific or schneider so if you get a remote from asda theyre really cheap less than a tenner - i found that look up either schneider or pacific and the first code it says should work for your tv!hope this helps!
Posted on Dec 14, 2008
SOURCE: remote control code for ONN tv, Model- LE 19L`cdd-vd0701`
Flat Panel Televisions I HAVE A SKY+ BOX AND NEED A Remote control code for ONN tv, Model- LE19LCD0801
Posted on Jan 03, 2010
  • 11800 Answers
SOURCE: need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
Posted on Jun 04, 2011
harshit_theg
  • 124 Answers
SOURCE: What are the remote codes for Sony RM-EZ4 / Haier TV, Comcast Xfinity cable box?
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. Press the SET button.
  3. On the remote control, press the appropriate component button.
  4. Using the number pad, enter the component's manufacturer code.
  5. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  6. Press the ENT button.
  7. Point the remote control at the component.
  8. Press the POWER button to verify operation.
Comcast offers several remote controls. The type of remote you get depends on the device you're using. Some Comcast remote controls are multi-device or universal remotes, while others only control the set top box and TV.
Posted on May 08, 2012
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
Apr 26, 2017 | Televison & Video
Need codes for my comcast remote
Comcast Remote Codes ' Program Your Remote Control
https://customer.xfinity.com/remotes/
Help and support with your XFINITY® Remote, select your remote control type and get the support you need to enjoy your XFINITY® TV!‎Comcast - ‎Find Your Comcast Remote ... - ‎Control Multiple Devices with a ...
Remote Control Help and Support ' XFINITY® by Comcast
Jan 18, 2016 | Televison & Video
Code for programming to a LG 4K tv?
  1. LG UHD 4K Television - LG.com‎
    Adwww.lg.com/UltraHD4KTVRatings:Reliability 9.5/10 - Picture quality 9.5/10 - Features 9.5/10
Search Results
    Find Your Comcast Remote Control Programming Code
    customer.xfinity.com/...tv/finding-your-remote-control-programming-co...
    Learn Comcast remote codes and more information on how to program your remote control. ... To Watch On Demand Programming with XFINITY TV:.
    DIRECTV - Remote Control Code Lookup
Jan 01, 2016 | LG Televison & Video
Nuvision tv remote codes for xfinity remote
NVU55FX10LS use 10690 Comcast / Xfinity SILVER Remote with RED enter button
Jun 16, 2012 | Televison & Video
WESTINGHOUSE LD-4655VX CODE FOR XFINITY REMOTE
The Westinghouse LD-4655VX TV has code compatibility with Sony TVs (http://westinghouseelectronics.com/wp-content/uploads/2012/06/Remote_Codes_2012.pdf). I accidentally discovered that the Sony TV remote RM-YD040 works with my he Westinghouse LD-4655VX (because I have both TV sets).
Feb 02, 2012 | Televison & Video
What code do i need for onn tv from thomson dt16300-16 remote control and how to do it
Hi Melanie, I tracked down the codes for your onn tv.
Onn TV Codes - 1179 , 0586
On the DTR remote Press TV,, now press
and hold OK and AV together. The TV button will flash twice. Now enter one of the 4 digit codes. Again the TV button will flash twice. If an invalid code is entered, the TV button
will only flash one long flash. If the first code does not work try the next code with the same sequence.
Incase you want the manual and remote codes to download, (click HERE for manual) and
(click HERE for remote codes).
Feb 11, 2011 | Televison & Video
Remote control code for ONN tv, Model- LE 19L`cdd-vd0701`
Mar 29, 2009 | Televison & Video
Comcast XFINITY TV Logo
768 people viewed this question
Top Comcast Apps Experts
Marvin
Marvin
ray gallant
Erin Wood
Erin Wood
Are you a Comcast App Expert? Answer questions, earn points and help others
