Question about KLH Audio Players & Recorders
How To Connect KLH Powered Subwoofer 10-100 C To Harmon Karden avr230
SOURCE:
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
VOTIT
  • 2071 Answers
SOURCE: Connecting KLH subwoofer to a Sony receiver
Just click and choose whatever hooked up connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Jan 07, 2009
SOURCE: KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Had the same problem with KLH E-10D Preamped Subwoofer. Afte brief research, I found the problem was with my Pioneer VSX-D509S reciever settings, not the subwoofer. If you have the same reciever, you can go to the pioneer website to download specific model owner's manuals.
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/ch.AV-Receivers.Archived?vgnextfmt=Archived
Select your Pioneer reciever model and it will give you an option to download the pdf manual. Hope this helps.
Posted on Jan 24, 2009
Bennytechkid
  • 99 Answers
SOURCE: i have a klh subwoofer about 6 yrs old.it keeps
Okay sounds like there is Fault in the power supply or the output transistor have shorted and is pumping the driver with DC....remove the driver and test with a muti-meter and using the 200 Ohm setting. put it across the terminals of the subwoofer make sure it is disconnected from the amp module....if it is a 8 ohm driver you may get somewhere from 4-8 ohm reading if its a 4 ohm somewhere from 3-6 ohms....if you are getting a 0 ohm or "short" or a really high or infinity "open" reading then the driver probably has caused damaged to the output transistors in the amplifier module. connect the muti-meter to to the red a black leads from the amp module that was going to the speaker...put the muti-meter on the highest possible DC voltage setting Mine goes to 1000VDC and power up the sub amp module now you may get a jump and power up but then it will drop to around 1.0v (or less) that is normal but if it stays high like anywhere from 30-150 VDC then you have blown output transistors (remember if you dont have this issue just skip forward!)...if this is the case pull out the amp module (remember to follow warnings and disconnect from mains power) now the DC filter caps in the module stay charged for long time after power is removed remember: test before touching!! now hopefuly all transistors are laid out infront and you wont have to dig for them the're normally are mounted flat and bolted to a external heatsink on the back. test between all junctions of the transistors B+E C+E C+B make sure there are no shorts...if there is a short replace the transistor. across from it there is its partner...replace him to! more than likely he's faulty because they work in whats called a Complimentary pair...the PNP pulls up the postive and the NPN pulls up the negative..together making a full audio signal. now after replacing all the faulty transistors test for DC on output leads. If there is none carefully connect a NEW driver of the same impendance as the old one.....but do not connect up the old one because you will blow the amp again....now power up and test for sound....all good????
Now if there is NO DC leaking on the Output leads but its still blows fuses there is a power supply fault! pull out the amp module now there is two types of power supply that this sub (or any amp for that matter) uses Switchmode Power supply (SMPS) or the normal transformer supply.im hoping for your sake it is a normal transformer supply it makes it soo much easier to fix....now be very careful you need to check the DC filter capacitors for shorting or any other issues! so undo the board from whatever it is mounted on, now remeber these capcitors can stay charged for along time so be sure to test before touching...if they are still charged and you want to dischrge them i use a 100W bulb (not an energy effiecnt bulb...but a Normal filament globe ) and connect up two leads to it...now put it across the capcitor banks...it will glow brightly and it will slowly dimm....power discharged!!
remeber to check that all caps are fully discharged!!
now test with muti-meter again on ohms mode and check for any shorts...now as you test the resistance will get greater as the caps charge up...this means all is good but if the meter stays at short then you have an issue with one of the filter caps (now if there is a short the caps will not have charge in them but still test!!) Now carefully remove each cap and test to finally locate the shorted one(s)...if there is no fault in Filter caps i would check the power transformer on the primarys so disconnect the leads from the power input socket (remembering the whole time we're doing this power is disconnected!!) and check with ohms meter there could be fault in which case you need to get a new transformer..if its not a faulty transformer.. i would be checking all mains power connections: the switch,interconnection leads,the fuse holder ect...to make sure there is no shorts...now if the power supply is a switchmode supply i would not even go there! i can repair them but it is way to hard to describe here and is not suggested for a DIY'er to attempt to repair but if its 6 years old it should be the way i have described above (normal transformer supply)......feel free to contact me if you need some more help in repairing this..E: ben@xdcpro.com.au
Depending where you are in the world most of the parts for amps can be sourced at local electronic stores or you could ask local repair stores to order parts in for you..if you are in Australia..if you want you can send me the numbers on the parts i can arrange them for you and post them out to you! good luck and i hope this can fix it,ben
Posted on Aug 11, 2009
  • 547 Answers
SOURCE: Have the KLH ASW10-120 Powered Subwoofer and it is blowing fuses
This model has a high failure rate with the power supply board. Typically, power resistors fail, which in turn burns out the big capacitors.
I have not heard of transformers failing though, so it shouldn't be too much to repair it.
Here are the schematics for the unit: Upper board and Lower board
Posted on Jan 11, 2010
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
How do i connect a set of Harmon Karden HK695-01 speakers to a Macbook Pro Mid 2010
HI Marc
Follow the steps below
Step 1:
Connect the green connector from the subwoofer into the headphone jack on the laptop, the black connector is not used, leave the rubber cap on the black connector to prevent static from the pin grounding on the system.
Step 2:
Plug the orange connector from the right/control satellite into the orange jack on the subwoofer.
Step 3:
Plug the brown connector from the left satellite into the brown jack on the subwoofer.
Step 4:
Plug the AC plug of the HK 965 into the wall outlet
Step 5:
Turn on the speaker set and adjust the volume accordingly.
PS: Do not Forget to adjust the Laptop volume also to minimize Distortion. Enjoy!
Jun 04, 2015 | Harmon Kardon Hk695 - 01 Audio System...
I have harman karden subwoofer but i dont have any
hmmm....does the subwoofer have any controls on it or are the controls on the speaker that came with the sub?
Jul 30, 2013 | Dell HK395 Computer Speakers
How to connect a subwoofer to a klh 5100
this unit has a sub output on the back to connect to a powered sub, or an amp/reciever and passive sub
Mar 09, 2013 | KLH R5100 Receiver
I have a Harmon Kardon HK3490 receiver which has an input for a powered subwoofer. Next to the subwoofer output is a "link switch" which turns on the subwoofer when I turn on the stereo. What...
Connect the Subwoofer Trigger Output for each subwoofer to thecorresponding trigger input on its amplifier. This enables the subwoofer toturn on or off together with the HK 3490. To further conserve energy,when the trigger connection is made, turn the Subwoofer Link Switch onto turn the subwoofer off when the corresponding pair of main speakersare not being used, such as during muting, when headphones are beingused, or when the main speakers are turned off using the Speaker 1/2 switch
Apr 05, 2011 | Denon AVR-687
My model 765S KLH powered subwoofer keeps blowing fuses (2 amp). Is it fixable and is it worth fixing?
I saw this post. I have the same problem with my 10-100.
http://www.fixya.com/support/t2753393-klh_subwoofer_about_6_yrs_old_keeps
Nov 13, 2010 | KLH ASW10-120 Subwoofer
Klh powered subwoofer keeps blowing fuses?
then the circuits took a hit and the fuse didn't do it's job in the 1st place. best is too get new circuit thats inside the sub woofer.
sorry to be the bearer of bad news
Apr 26, 2009 | KLH BB-II Subwoofer
Best picture and sound
connect coaxial cable connector from your cable service company to cable box-----in jack.
2-using coaxial cable connect cable box out to tv-vhf/uhf jack.
connect projection tv audio out (var-fix)jacks to avr 230 line in.
Aug 22, 2008 | Audio Players & Recorders
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
