So no English?, OK I'll nibble the hook...
so I google translated it for you like this: I added punc.
"My pc is down.
fan and hard drive turn around, but nothing on the screen.I would like to know if it is the motherboard or the processor: 1333 Acer Q45T-AM V: 1.1 15-V59-011100 DDR3"
----------------------------answer------------------------------------------------
if the processor is on the Acer.com qualified processor list then the processor is good, with heat sink and fan, never missing.
first of all the actual PC is not stated, you post only a RAW motherboard and then not show a photo of it in use.
so answers are hard won, and log... if at all.
no monitor stated, no PSU stated, no cables types stated,
VGA? DVI., HDMI> ? on board video jack or PCI video card?
so is it CPU bad/wrong or fan dead?
is it mobo bad
is it monitor gbad
is it DDR stick bad.
is it VGA port dead on mobo or cable.
is it PSU dead.
6 possible things not 2.
one more the power pin must be jumped, for 7 things wrong.
8 possible if using VGA card.
there is no PSU aux jack so no newer v2.2 PSU needed.
http://pcdied.com/intel-magic/min-mobo4w1.jpg
SOURCE: CPU
test the bios battery, it should read 3vdc. if that fails, remove the bios battery, remove and re-socket the cpu and memory, then hook the bios battery back up. once booted, go into the bios, restore factory or fail-safe defaults, save, and reboot.
let me know if this helps,
trin
broken french translation:
examinez la batterie de bios, elle devrait lire 3vdc.
si cela échoue,
enlèvent la batterie de bios, l'enlèvent et re-douille l'unité CPU et la mémoire, puis accrochent le dos de
batterie de bios vers le haut une fois initialisé, entrent dans
le bios, reconstituent l'usine ou les défauts fiables, économiser,
et les rechargent.
faites-moi savoir si ceci aide,
trin
SOURCE: Mon PC ne reconnait plus mon disque dur
I have a maxtor 40gb DiamondMax Plus 8, and suddenly, my computer only recognizes over my hard drive. I work on XP, but the hard drive is in my computer for at mons three years. Not a problem before. It is partitioned. Can I chdisk from DOS, or else. Thanks for your help.
Dacha
That is what you wrote:
Check in menagment console if you found there.If not check IDE CABLE if it is put in corectlly and check electricity!
SOURCE: disque cod?
To have answers in these types of groups it is best to translate in to English.
The question in English:
Hello, I have a problem with a laptop which called for a password bios. Well, I removed the battery for a moment and that is installed. I launched the boot on the disc cd then it did the restart, it asks me a password hard disk. I then passes through several means even SKY_FOX I tried but nothing.C 'is a brand Fujitsu Siemens Lifebook and I do even more started on the system' exploitation. I really need help, if you could do something without needing expensive experts. Thank you.
__
Have you contacted the former owner to get the password?
If the hard disk is pass-word protected and you do not have the password, the fix would be to un-install the partition, and re-make it. Then do the full re-installation of the operating system, and the re-registration for ownership.
In some cases where the hard disk is password locked, there may be no possible way to be allowed to undo and re-make the partition to do a full re-install. If this is the case, changing the hard disk will fix it. The old hard disk would be scrapped unless you can have its password.
BIOS Level Password Procedure:
With some models of computers, you can remove the BIOS battery and wait until the BIOS setup is depleted. Then you should then be able to have access to re-set up the BIOS. You will have the choice to put in a new password or simply not to.
If the computer hardware is pass-worded at the BIOS level and it does not deplete with the battery removal, you will have to send the computer back to the manufacture to have the computer un-locked. You will have to pay the shipping and the service fee. When sending the computer back to the manufacture for the unlock, you will be asked for proof of ownership of the computer with proof of identification. With most computer companies, a copy of the purchase invoice, and a copy of your driver's permit or citizenship card should be acceptable.
________________________________
Google Translated, Answer in French:
Avez-vous contacté l'ancien propriétaire pour obtenir le mot de passe?
Si le disque dur est mot de passe protégé et vous n'avez pas le mot de passe, le correctif serait d'installer un-la partition, et re-faire. Ensuite, faites le plein de nouveau l'installation du système d'exploitation, et le ré-enregistrement de la propriété.
Dans certains cas où le disque dur mot de passe est verrouillé, mai il ne peut être moyen d'être autorisé à annuler et re-faites une partition de faire une re-installer. Si tel est le cas, changer le disque dur fixe. L'ancien disque dur serait supprimé à moins que vous ne peut avoir son mot de passe.
Mot de passe BIOS niveau procédure:
Avec certains modèles d'ordinateurs, vous pouvez supprimer le BIOS batterie et attendez jusqu'à ce que le BIOS est épuisé. Ensuite, vous devez alors être en mesure d'avoir accès à re-configurer le BIOS. Vous aurez le choix de mettre en un nouveau mot de passe ou tout simplement ne pas le faire.
Si le matériel est libellée au passage à niveau le BIOS et ne pas épuiser la batterie avec le déménagement, vous aurez à envoyer l'ordinateur à la fabrication d'avoir un ordinateur sans littoral. Vous devrez payer les frais de livraison et les frais de service. Lors de l'envoi de l'ordinateur à la fabrication pour la déverrouiller, il vous sera demandé une preuve de propriété de l'ordinateur avec la preuve d'identification. Avec la plupart des sociétés informatiques, une copie de la facture d'achat, et une copie de votre permis de conduire ou carte de citoyenneté devrait être acceptable.
Jerry G.
SOURCE: Je voudrais debloquer mon sonyericsson w200i pour tout resau svp
There is no free unlock as yet for W200i CID53 mobile...you will need to try online at topsony.com or take the phone to a mobile center and have it unlock there.
