alan mann Posted on Dec 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My epson tx550w only prints every second line
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Jan 20, 2019
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1813537
Points
14613
Nozzle Clogs This is the number one cause of banding and can happen somewhat regularly on Epson and other inkjet printers. Banding from nozzle clogging usually shows up as lighter and off color horizontal lines running through the print. ... Click the button and a test pattern will print.
Follow the steps below to clean the print head using the Head Cleaning utility. Make sure that the printer is turned on and the ink out light is off. Access the Print or Page Setup dialog box and click the Utility icon button, then click the Head Cleaning button.
4 Related Answers
jsimpson2008
  • 24 Answers
  • Posted on Mar 27, 2010
SOURCE: My USB is not recognised when I try to scan with Epson TX550W
more info os type ie. xp vista win7 and type of puter and wired or wireless printer?
digivisionm
  • 40 Answers
  • Posted on Aug 15, 2010
SOURCE: I have epson Stylus TX550W I
chk ur print head, u can clean head with maintenance software
Anonymous
  • 504 Answers
  • Posted on Aug 08, 2011
SOURCE: Epson TX550W printer is off
ir your printer have lan port follow the following line
1- check ip in your printer software
2- give ip in yr pc same range
3- try ping to printer ip
4- if yr printer have html self support than simply type printer ip at yr browser check all parameter
5- add printer from control pannel with network printer option and five printer ip
vikas verma
9415563660
maxcarson
max carson
  • 7627 Answers
  • Posted on Dec 15, 2012
SOURCE: I want to print on my epson tx550w via wi-fii
Wired or Wireless or both?( I have no idea what you are connecting, Laptop , desktop, OS, equipment, etc.) Is the printer connected via a printer cable to your desktop or does the desktop have a wireless card? Or is the printer Wireless? Three are to many open questions to list every option, take a look at this: http://compnetworking.about.com/od/hardwarenetworkgear/a/how-to-network-a-printer.htm. With more detailed info I can assist you better. Here's a Google search: http://www.google.com/webhp?source=search_app#hl=en&tbo=d&sclient=psy-ab&q=adding+a+wired+or+wireless+printer+to+a+ho
Epson TX550W printer is off line. How do I connect it via the LAN?
vikas verma
9415563660
2helpful
Epsom TX550W Doesn't recognise replacement cartridges
Are they official cartridges? If not, are they direct replacements for the Epson versions of the cartridges: Epson T0732/T0732N/73N Epson T0733/T0733N/73N Epson T0734/T0734N/73N
If they are, have they been refilled or bought fresh? If they have been refilled, have they been re-programmed? Have you updated your printer firmware recently?
1helpful
My TX550W ran out of Black Ink (T103) and I replaced it with a Genuine Epson Cartridge compatible with my printer (73N), My computer status monitor/ink check on the printer shows the black ink is now full...
Sometimes the ink does take a while to come from the cartridge to the print head. Performing 1 head cleaning procedure may fix this. But only do this once, anything after is just wasting ink. Also make sure no part of the air tab sticker has blocked the air hole in the cartridge. Have a look at the new one you have to find the hole. Its just under the sticker you take off before installing it into the printer.
I hope this helps Regards GM
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
