Question about Nintendo Wii Console
My wii console will not power on. have checked all plugs and everything is connected and outlet has power
  • 6,784 Answers
HI. the power supply board has failed. There is a fuse(3amps) inside the power supply unit. you will need to remove the cover from the power supply to access this fuse. once inside the power supply, inspect the fuse. if it is truly blown, replace it. if the fuse is not blown, this will confirm a failed power supply unit. it should be replaced in this case...
Posted on Aug 05, 2009
SOURCE:
After working just two days ago. The console will not power on. It has not been moved. We have unpluged everything,no luck.
Hello
Start simple. If there's no power to your Wii, check that the AC adaptor is firmly connected both to the game console and a live electrical outlet. If you still have no power, or the power LED light goes off in midgame or flickers, try rebooting the system. Turn everything off, unplug the AC adaptor from the electrical outlet, wait at least 60 seconds and then plug in again and turn the system on.
If this does not help you may need a new power supply.Also try cleaning the wii.Use a can of ampressed air to blow out any dirt or dust from unit.Pay attention to fan area.Be sure fan spins free.
Sep 23, 2011 | Nintendo Wii Console
Wii will not turn on even though it has power and everything is connected. Help?
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Dec 09, 2009 | Nintendo Wii Console
Console will not power up
Try to reset the AC adapter.
Unplug everything from the console, then unplug the power cord from the Wii and the wall outlet. Let it sit for 60 seconds and plug it back in.
Aug 02, 2009 | Nintendo Wii Console
My wii does not turn on and all connetions are plugged in
Make sure power connection firmly in both ends.
Change power outlet... if plugging in to strip TEST directly to wall outlet.
Try differenct wall outlet.
Try different WII power adapter.
Jul 28, 2009 | Nintendo Wii Console
Wii console won't turn on
If you all have access to or have a voltage meter youll need to test that its getting 110v thru the power supply...Its the most likely villain
May 15, 2009 | Nintendo Wii Console
Power Outage & Now Wii Won't Power Up...
When this same thing happened to me, I unplugged the Wii power supply from the wall (not just from the back of the Wii) and let it sit unplugged for about 10 minutes. When I plugged it back in, everything was fine.
Nov 11, 2008 | Nintendo Wii Console
Storm last night, now Wii won't power up
Unplug everything! There is a "breaker" in the power supply and it may need to be reset. Just unplug all cables from the TV and outlets. Let it sit for a couple hours then plug everything back in and it should work fine. If not then the power supply has shorted out due to a strong power surge. You can claim it under your home owners insurance or call Nintendo and try to get it replaced. Thanks! Good luck and happy gaming!!
Aug 31, 2008 | Nintendo Wii Console
My wii will not power on
Unplug the Wii from EVERYTHING....TV, the outlets...let sit for a while and plug everything back in. Worked for me
Aug 01, 2008 | Nintendo Wii Console
Connecting my WII
Connecting a Wii is simple, to connect first Plug your Wii into a wall power outlet, the plug the AV or three pronged jack into the corresponding colors in the back of the TV, Next plug in the Wii sensor bar to the back of the Wii Console and mount the sensor bar on top of the Television. Turn the power on to your Wii and connect your Wii-motes. Enjoy!
Feb 16, 2008 | Video Game Consoles & Games
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
380 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
