SOURCE: converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
SOURCE: samsung gas dryer convert to propane
I purchased a Samsung steam gas dryer and found that no one in our area knew anything about them, Fortunately I am a gas tech. but have never worked on this brand. The first thing is you should always use a gas technician before doing this. Secondly turn off the gas and electricity. You must remove the two screws from the back that hold on the top of the appliance and set this aside. Then lift up the front electronics and disconnect the wiring harness, once you've done this there are 5 screws along the top of the silver strip or door area. This will alow you to lift up the front and disconnect the wiring harness and set aside. now you can follow the instructions on converting your dryer. PLEASE check for LEAKS and proper gas flow. Follow the same steps in reverse to put the dryer back together and happy drying.
SOURCE: want to convert pitco frialator model 14 from gas to propane
I agree - What everyone fails to tell you about conversion from Natural Gas to Propane -
1 - Take your time -
2 - The parts you get may be to many
3 - If you are going to use the unitl out-side - Wind is not your friend -
4 - While 20lb tanks will work - 60lb tanks are the best
I have found that only 70% of the gas in a 20lb tank will be used - the Amount of preasure / volumne decreases as the tank gets empty - a gas grill will empty a tank - a Deep Fryer (I have a Pitco 14 and 35c) will not - therefore, 60lb tanks
5 - Also, a 3/8 hose and connections will work, but 1/2 hose and connection work better - especially with a 60lb tank
6 - Find a good welder supply store to work with to get the hoses and adapters - Stay away from Lowes, Home Depot and other Box Stores - They are ok for most things, but not this project - Pay the extra money for the right stuff.
1 - Have 3/8, 7/16 and 1/2 wrenches - Open and Box style
2 - A very good philips and slotted screw-driver
3 - Remove the Front Door and Front Panel
4 - Remove the Burners - Be careful - they are heavy and if dropped, they do crack
5 - The orfices for the burners are simple to change
6 - The Gas Regulator on the Control valve is simple - not easy to get to, but simpe to change - and make sure it is tight, (so it does not leak) but not to tight - it can craxk
7 - The silver thimbel - it is a atomizier for the pilot - is also easy to replace, but hard to get to - don't bend the gas tube to much and be carefull removing the old one - it is jamed into the pilot
8 - Wind - IS NOT YOUR FRIEND - If outside, you need to cover the left, back and right side from wind - it will push the gas out of the burner (at the orfice) and into the cabinet and it will "POP" with gas - the orfices will have little flames on them - very yellow and very bad -
SOURCE: Convert Whirlpool dryer from propane to gas
I have a whirlpool dryer as propane and needed it converted to gas. I have the orifce -gas kit which consist of two parts. Which part do I use? Is it the one which screws in and mist hole is on the other end, or the other one it comes with that has the mist hole on the other side.
The one i placed was the later ( one with mist hole on the side)
