Electrical Supplies Logo
A
Anonymous Posted on Dec 20, 2018
DURALAST JUMPSTART 900 - NOT CHARGING
LIGHTS ON BUT NOT CHARGING.
john h
Level 3:
Top Expert:
  • Electrical S... Master 29,494 Answers
  • Posted on Dec 20, 2018
john h
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7559556
Points
193449
Check and test the battery
Steve Pack
Level 3:
  • Electrical S... Master 7,128 Answers
Steve Pack
Level 3:
Answers
7128
Questions
Helped
2275928
Points
27978
Either the charger is bad or the battery is no good.
1 Related Answer
Anonymous
  • 85 Answers
  • Posted on May 23, 2010
SOURCE: Hello. I have a duralast jumpstart kit. After
Hi, usually after you drain the unit down it will take up to 4 hours for it to charge up 100%. but do not leave it on the charger all the time when not in use because this decreases battery life.
What size battery do I need for 2002 cavalier 2.4
Batteries, Starting And Charging at AutoZone.com - Best ...
www.autozone.com/parts/batteries-starting-and-charging
AutoZoneShop for Batteries, Starting And Charging products with confidence at ... Parts are just part of what we do. ... 1994 Nissan/Datsun Altima 2.4L SFI DOHC 4cyl.
Batteries for Chevrolet (Cavalier and Vega) - AutoZone
www.autozone.com/1/categories/chevrolet-cavalier-batteries
AutoZoneProducts 1 - 10 of 10 - Chevrolet Cavalier Batteries including Battery 75-DL - Duralast (75-DL), Battery 75-DLG - Duralast Gold (75-DLG), Battery 75s-DL ...
Does the light have to be blinking on my duralast 750 jump starter for it to be charging
I'd suggest checking your user manual. If you don't have one, you can download one from the duralast site.
Jan 26, 2015 • Motorcycles
Can a Duralast jump starter kit start a car while plugged into an outlet?
The charger to a Jumpstart charges at a low rate (300mA to 500mA) and will not push enough current to start a car. Best to have Jumpstarts recharged every 6 months to be ready for emergency.
1helpful
2answers
I have to power 1800 w for 12hr a day! I currently have Vector Max SST 3000w 20 Duralast 31-950 950 Cold Crankin Amps 195 Reserve Capacity Schumacher se-3000 Charger Do i need to change or add anything to...
I think the problem might be your battery setup.
First of all, these batteries are not deep-cycle batteries they may not tolerate this kind of usage. Secondly, if you have 20 batteries connected in parallel they could end up working  against each other (draining each other) all the time.
You might do better with 2 very large 6 volt deep-cycle golf cart or fork lift batteries.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
