Question about Amana Heating & Cooling
I'm not getting any code after installing a control board for my Amana ptac?
SOURCE:
oscarn
  • 110 Answers
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
  • 6 Answers
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
Posted on Sep 09, 2008
  • 142 Answers
SOURCE: Amana PTAC ptc093d35ar, when i
H1=High voltage protection engaged. Power supply voltage is too high. Check for incoming power at correct voltage.
Posted on Feb 10, 2009
  • 142 Answers
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Posted on Feb 12, 2009
milten1
  • 1304 Answers
SOURCE: How do you check to see if the circuit board is working on a unit
open your control area,
check your l1 and l2 conections this unit is usually 220v
the control is this simple
voltage in no voltage out change the board
Posted on Oct 24, 2009
What does it mean when it indicates stop?
Wow, a talking AC?
How to Reset an Amana PTAC - YouTube
? 0:55
www.youtube.com/watch?v=D4SQfFChiKY
Mar 28, 2014 - Uploaded by Total Home Supply If you ever need to reset your Amana PTAC this simple guide will ... HVAC AC Blower not working, troubleshooting Fan Control board, Fan not ...
Aug 21, 2015 | Amana Heating & Cooling
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
Amana PTAC will cool but fan will not go up in speed
Change the thermostat wire , if not change your board.
Jun 02, 2012 | Amana PTH123B25AJ Heat Pump Air...
I have installed the new control board for my rsk0009 ptac heating and cooling anyway ive input all the correct codes and still the air conditioning compressor does not turn on what do i do?
Reprogram the board to run in C mode only
Hold +- down Press OFF twice
HEAT twice then + once
Then OFF Apply heat to the BLACK themistor indoor coil Check results
You did replace the RED BLACK and BUE thermistors didn't you?
Nov 27, 2010 | Amana Heating & Cooling
I have thru-wall PTAC Amana PTH093B35AM unit. I
see if you can find a new board the power failure fried it
Jun 19, 2010 | Amana PTH093B35AM Thru-Wall/Window Air...
Amana PTAC cannot be turned on.
sound like a thermister problem, however this may also be a circuit board problem, the system is controled by the outdoor board, check to see if you have a blown inline fuse in the outdoor unit, it will be under a red case in one of the wires.
Jan 28, 2010 | Heating & Cooling
Oct 24, 2009 | Amana PTH123B25AJ Heat Pump Air...
Ptac not heating
the board or the heater need to be replaced
Dec 23, 2008 | Amana AAC051FRB Air Conditioner
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
WatsHVAC
Level 1 Expert
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
