Refrigerators Logo
A
Anonymous Posted on Dec 19, 2018
Hello, I have LG refrigerator Gr-s352qvc, it's cooling well, but it's not getting cut off, I changed the settings to minimum also, but compressor continuesly running. Not getting cut off. Plz give me the answers.
Chris Huff
Level 3:
Top Expert:
  • LG Master 6,289 Answers
  • Posted on Dec 19, 2018
Chris Huff
LG Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017836
Points
74913
Is condenser fan running?
  • 2 more comments
  • Anonymous Dec 19, 2018
    Yes condenser fan running
  • Chris Huff
    Chris Huff Dec 19, 2018
    Thermostat or control board issue most likely
    It's digital thermostat with led indicator
    Is it inverter linear compressor? lg gr-s352qvc model.
Where is the timer for controlling defrost located in LG refrigerator Model GR-S352QLC double door.
The timer for controlling the defrost cycle on your LG refrigerator model GR-S352QLC is typically located behind the control panel or near the compressor at the back of the
To access the timer, you will likely need to remove the control panel or the rear panel of the fridge. If you are unsure of the exact location of the timer or are having difficulty accessing it, you may want to consult the manual for your specific model of LG refrigerator or contact a qualified technician for assistance.
My LG GR-S352Qvc FREEZER IS WORKING , BUT THE DEFROST HEATER IS NOT WORKING, WHAT IS THE PROBLEM?
can be several things, test element with a multi meter make sure unit is unplugged first,if good check defrost timer by manually turning into defrost mode check to see if element comes on if it does replace timer,if still no good it may be the defrost termination timer which is a bit more complicated
Hello my LG GR- 267THF compressor is not work I want new compressor so please help me.
Installing a new refrigerator compressor requires some specialized skills and tools. Removal is simple, but re-installation requires skill at silver soldering, a vacuum pump, a refrigerant measuring tool, a crimping tool, etc etc.
Refrigerator will not restart for a very long period of time after power cut.
there may be a faulty capacitor for the compressor motor
I would suggest a technician check it out as it should come back working within minutes of a power cut
there will be a short delay until the pressures even out as compressors have difficulty starting under pressure but you delay is extreme and needs checking out.
Lg fridge GR-B3993LQ is not cooling
Make sure that the thermostat is working and that the compressor and associated fans are working (getting Power).
If both units are working and still no cooling your evaporator could be frozen because the defrost timer/element is not working. Worst case scenario is that you may have developed a small leak and lost refrigerant.
Lg gr 282mvf shematics
You will need a tech to check everything properly.
LG Model GR-B429BLQN not getting cold.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
LG GR-602TVF Top Freezer
turned out to be the compressor all fixed and working fine now
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
