Ovens Logo
J
Jasanda Watson Posted on Dec 19, 2018
Have 20 year old Maytag convection wall oven. Model CWE9030B. It started beeping with a F7 display. Did stop beeping with oven light on and door open. Any advice?
jaminxray
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Dec 19, 2018
jaminxray
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
Helped
195
Points
6
The F7 error code indicates that there is a problem with the buttons of the control panel. The code comes on when two or more buttons are stuck at the same time. The oven cannot operate when this condition exists. The oven is repaired by replacing the control panel with a functioning one. You may try to tap on the control panel lightly to see if one of the ttons is stuck down.
5 Related Answers
Anonymous
  • 166 Answers
  • Posted on Sep 07, 2008
SOURCE: Jenn-Air Convection Wall Oven, WW2780
I your user Manuel should be a list of error codes describing what each error code indicates!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Anonymous
  • 126 Answers
  • Posted on Nov 12, 2009
SOURCE: oven door locked
ah, you lucky guy. You can try a hard reset by unplugging the range for a good 1/2 hour, then plug back in. Unfortunutely this probably won't work, as these clock/timers are notorious for only lasting a few years. You have to blow $150+ and replace the clock/timer. Note: A hair dryer will help you get the face off the old one to put onto the new one.
Anonymous
  • 30 Answers
  • Posted on Dec 08, 2009
SOURCE: Kenmore oven keeps beeping, shows F7 on display.
Please, don't replace anything before trying this first! The insulation in the ribbon cable is poor, so the conductors in the cable become crossed. The ribbon cable is actually two ribbons pressed together, and the conductors between the two cables are shorting or becomming crossed. Lift the two cables apart, place a piece of paper between them, fold the edges of the paper over the cable so that it does not slip out, and make sure to shove it all the way down to where it will meet the plastic display panel housing. There, problem solved, and you didn't have to buy new parts.
Anonymous
  • 15935 Answers
  • Posted on Sep 25, 2010
SOURCE: error code f7 on Kenmore wall oven 911.41165791
The F7 error code indicates that one or more potentiometers (burner switches) are not connected properly or that you have one or more failed potentiometers.
The specific details of this failure code are provided in the second image below.
This is an excerpt from the technical information for this range.
Normally, a service technician would be needed to conduct the troubleshooting and diagnosis for this type of failure.
If you are completely confident in your technical ability to safely unplug the range and access these potentiometers (54 in the third image example) you may be able to check for loose or broken wires that could be causing this code.
If no loose wires are found, then you will likely need to have a technician find and replace a failed potentiometer.
IMAGE1: http://media.fotki.com/1_p,wfdddkwdfrwkdtqxgtqsskgwtqkq,vi/gfwdtqtbrxgdkgqwqtb/1/1303472/5961857/image11662img-or.gif
IMAGE2: http://media.fotki.com/1_p,wfdddbrbbbbgfttxgtqsskgwtqkq,vi/gsfkbbsqqxgdtwdgbsg/1/1303472/5961857/image11663img-or.gif
IMAGE3: http://media.fotki.com/1_p,wfddfqsqwsbqtrwxgtqsskgwtqkq,vi/gtfggdrdwxgftrgbbtf/1/1303472/5961857/image11664img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Thomas Smithbrother
  • 3698 Answers
  • Posted on Jun 30, 2014
SOURCE: Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
F7 error code jenn-air wall oven
My 20 year old electric Jenn Air range recently flashed the F7 error code and beeped repeatedly. I shut off the circuit breaker until it cooled. The next day I turned it on and everything seemed fine. We baked a pizza and the
erro repeated when the oven was shut off.
I opened the front panel and noticed the wire ribbon connecting the front panel to the display was slightly askew. How that happened is beyond me. I pulled out the ribbon hold down clips, pushed the ribbon in all the way, and
replaced the hold down clips. The range is now working properly after replacing nothing.
The cheapest fix possible.
We have a 30" 15 year old wall oven with an F7
Hello, ante
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from
repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help , I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Maytag MEW6527B Oven.Push panel buttons,no beeps or codes. Convect roast starts at temp 888 then adjusts to 550, for 11:11 time, only #'s that work. Checked Sab mode, door lock, panel lock. Circuit...
I had almost the same problem I to have a Maytag.I was not getting any readings from my panel and the oven would not work.I called up Maytag and they told me to move the oven away from the wall.Whats happens the computer board heats ( Display ) up causeing this problem.I moved the oven a little bit away from the wall and now it works great.I hope this helps you.
My oven beeps and show error code F7 on the panel. Help!!!
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
2helpful
What does F- mean on my jenn air expressions electric wall oven? If it means what I think, then this is the 4th failure in 10 years. This just can't be right!
Common fault codes:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
You will be fine
Bless You ngafm
Sep 06, 2008 • Ovens
GE Profile 2002 Wall oven JCKP18BA2BB Code faults
Try my solution for the F7 problem at the following link:
http://www.applianceblog.com/manuals/Dreaded_F7_Problem.pdf
I have shared this with over 1500 folks and most report success.
Please let me know. Also, what is your model number, how old is your oven and where are you located? I am making a study of this problem. You can email me at: [email protected]
Jan 08, 2008 • Ovens
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
