SOURCE: mcculloch 110 - loose chain
Look at the saw body from the nose of the bar, Just to the left of the bar a slotted screw head should be visible (on clutch cover). That is your tension adjustment.
Chain adjustment
SOURCE: hi, my mcculloch chain saw is not cutting
Use a file around the perimeter of the bar at about a 45° angle, both sides. Remove just enough metal to see where the file has been. I think you have a wire edge that is causing the bar to cut at an angle. Be careful it is sharp. If that is not it post back below. Good Luck. HTH
Lou
SOURCE: how to tighten the tension on M4218 Maccoulic
A link to your OM follows, the procedure is on page 8 and appears quite good.
http://weborder.husqvarna.com/order_static/doc/MOEN/MOEN2009/MOEN2009_545154793.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: I need to tighten the chain. Is there a way to do
there should be a screw at the back end of the bar.Screw it in to push the bar out ,or forward, thus makeing the chain tighter
SOURCE: mcculloch electramac ems300s chain is loose how to tighten
A link to an OM for a similar model follows:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-MCC1514-6096210915-966993001.pdf
Tension adjustment is on page 10. All chains are adjusted similarly, this one is reasonably complete, the only addition I suggest is to elevate the nose of the bar when adjusting and tightening. Experience tells me adjustments require many fewer tweaks when the nose is elevated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
