Question about Necchi Sewing Machines
My Necchi super utility was rattling in the area where the light bulb is then it just stop working.
I changed the light bulb in necchi automatic supernova ultra mark 2 and still no light
In that case, I would assume a 'short' in the wiring. Which you could find with a current tester. Hubby has one, not that he has taught me how to use it. Or - My industrial machine has no light, so I've picked up a nifty folding lamp with ? - a light source that provides solar light spectrum. Check at thrift stores, or at any Wal-Mart. Not all that pricey, now.
Feb 08, 2018 | Necchi Sewing Machines
Who Are the agents for Necchi Machines In Sri Lanka ? I want to repair my Necchi Machine Model No 549.
go online to necchi web site and look for parts or the nearest distributor /agent in your area or search for parts repair shops that carry their line of products
Nov 18, 2016 | Necchi Sewing Machines
How do you change the bulb in the necchi omega 6018
there is a door on the left it's called a lamp cover door or a face plate- on my mechanical necchi there are hinges behind the door at the back,,gently pull open the door & the bulb will be accessible
on my other necchi there is a cap in the middle of the door with a hidden screw, gently pry the cap out & take out the screw & there is the bulb,,just reverse the process to put the door back on
Dec 08, 2010 | Necchi 6018 Mechanical Sewing Machine
I own a Necchi model 535f......I have had it cleaned and oiled in the last 4 years....I can't get my fabric to feed through my machine
The feed dog & the presser foot have to work together to feed the fabric thru the machine
The feed dog should be seen when you look at the needle plate, if not the feed dog setting should be checked--the feed dog lever may be to the right of the bobbin area
Open the light bulb door also called the Lamp Cover door or Face Plate,, there should be a knob at the top round or star shaped,, that adjusts the needle bar that puts pressure on the presser foot,, it may have numbers or letters, mine is a star shape & has numbers on it & is set between the 2-3
Adjust it a little at a time & then sew to see which setting is best for your machine
Oct 21, 2010 | Necchi Sewing Machines
My Nechhi Royal Series Sewing Machine Has stopped working
Make sure the stop motion wheel is tight, make sure you do not have any thread stuck in the raceway area if you get a buzzing sound from the motor
Feb 17, 2010 | Sewing Machines
Replacement bulb for a Necchi 537FA
it's the same size as a night light bulb. That's how I replaced mine. You can pick one up at any hardware or dept store.
Oct 31, 2009 | Necchi 3537 Mechanical Sewing Machine
Need belt for necchi supernova automatica sewing machine
You can also use a Eureka vacuum cleaner belt, can't remember the exact model, but the package says it's for most sewing machines. It's not the V belt, but it works on my Super Nova and it's 1.79 for two!
May 09, 2009 | Sewing Machines
Sewing Machines Logo
20 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
