Its displayes E45 on upper drawer and drawer stuck
Reset Procedures for the Fisher & Paykel Dishwasher
SOURCE: F4 error on fisher and
No increase in water
temperature during
wash cycle. --->
Faulty element.
Electronics controller
faulty.
Faulty temperature
sensor.
Check the heater thermistor and the wires to both...
SOURCE: How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
SOURCE: Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
SOURCE: fisher paykel drawer dishwasher is stuck open and
Hey I dont know if you have this problem, but with mine the gasket seemed to be blocking the opening, so you could close it, but you had to shove a lot. The FP help line said to just unplug and replug in the unit. I did it and lo and behold it worked fine again. It did seem to leak a little bit the first time I reran it, but that seems to have gone away. Hope this helps
