SOURCE: sc-d353
hi the ribbin in the lcd wears after a time it rubs on the side as you open the lcd a common fault i have just fix min £20 for new ribbin
SOURCE: 1994 laredo jeep overheating
My 1999 Jeep Grand Cherokee has run hot for the last year. The garage changed the thermostat 3 times and didn't solve the problem. Decided to look at it myself. Thought the radiator might be the problem - clogged? To remove the radiator the headlights, grille, and bumper cover etc needed to be removed. Turned out the radiator was clean inside and held pressure. Problem was junk between the fins stopping the air flow. Radiator shop blew out between the fins with air and it's worked great since.No more overheating.
SOURCE: my craftsman 1/2 hp garage door starts to close and then opens up
I had a simular issue, except mine was that the previous owner decided to mess with all the settings and mounts and screwed everything up.
The problem isn't your force sensors its your downwards stopping sensor on the opposite side of the opener. For me I had to take the entire panel off and replace the sensor back in its holder, but try adjusting that sensor setting (clockwise goes down, counterclockwise goes up).
If that doesn't work then i dunno:)
Also set both force settings in between 0-1, for some reason with mine if i set it higher it would set them off....
SOURCE: COBALT TEMP GAUGE READS 250 DEGREES BUT ENGINE
Probably the temp gauge itself. Most of the time it doesn't have a problem but sometimes they do go bad. Did the car ever overheat prior to changing the solenoid?
SOURCE: new goodman 2.5 ton 14 seer with txv. suction
it is fine and sounds like it is running at a high efficentcey. I wouldnt worry about it as long as it dosent cycle too much.
Hi
This means a
loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
