SOURCE: bobbin holder
Make sure the needle is in the highest position before you try putting the bobbin holder in. The bobbin holder has a metal 'finger' which fits into a 'slot' in the housing and it only goes in if you have the needle up.
SOURCE: bobbin case does not stay in place
I looked at the 4210, here http://www.singerco.com/accessories/manuals.html
And I do not see any adjustment. Refer to the page for installing the bobbin - are you using the right size bobbin?
SOURCE: Hi, the bobbin holder on
I am wondering if you are using a different bobbin, in your manual, it specifically states that you have to use an SA 156 bobbin not one from an older machine. If, you do not use the right size it will act like you are talking about. I know that you should check that out.
SOURCE: I have the Kenmore sewing
For a comprehensive 5 page illustrated tutorial...Check this solution link, just copy & paste:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
SOURCE: singer 9410 Bobbin Repair
it sound like the machine needs to be serviced by a sewing machine repair tech
