Question about Casio Office Equipment & Supplies
Casio PAG-40 one function button no spring
Mode button does not spring out when released.Also, cannot get compass to work. Have reset it according to manual more than 6X, it stilo doesn't know which way is west, or east!
5 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Posted on Mar 06, 2008
escapement
  • 2338 Answers
SOURCE: the screen is swithing between compass - baro -
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
Posted on Feb 27, 2010
SOURCE: Casio PAG 40 I took it apart to replace bateries and a spring came out and I don't know where it goes. The 2 gold ones are in place.
It's probably the small spring which makes electrical contact between the watch aluminum back and the outer housing, presumably to provide an electrical ground connection to the outside triple sensor. I've attached a photo with the location indicated by the yellow circle and arrow. It goes in the little hole and will fall out if you're not careful.11_14_2012_6_41_27_pm.jpg
Posted on Nov 14, 2012
small6363
  • 18429 Answers
SOURCE: How do I turn off the automatic setting for the
here is the manual
http://support.casio.com/en/manual/009/qw2271.pdf
Posted on Apr 07, 2014
MX300 waste ink full
1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED
4) When the Power LED lights in green (and "ServiceMode Idle" is displayed on the LCD), press the Stop/Reset button the specified number of time(s) according to the function listed in the table below, then press the ON/OFF button. (Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED
1) In the service mode, press the Stop/Reset button 4 times to enter the ink absorber counter resetting mode
2) In the ink absorber counter resetting mode, press the Stop/Reset button the specified number of time(s) according to the kind of ink absorber whose value should be reset to 0%.
Aug 13, 2014 | Canon PIXMA Office Equipment & Supplies
2006 Expedition overhead compass reads "N" when heading "E". Wonder how to reset it so it indicates the direction accurately.
Yes. Wish I could tell you which button for sure, but to reprogram the Compass you hold one of the buttons and drive in a circle one or two times to reacquire your position.
Apr 08, 2013 | 2006 Ford Expedition XLT
Nov 06, 2012 | Casio PRG-40T-7 Pathfinder
When using the barometer or altimeter on my my pag 40 - 2271 it shows err. How do I fix it? Do you know what page in the users guide shows how or gives directions on how to fix?
Same problem with my SPF-40, module 2273, after a small helical compression spring, silver color, fell out. I could not determine where it is suppose to be located. It could be the barometric reference spring for sensing the barometric pressure.
Nov 18, 2010 | Casio PRG-40T-7 Pathfinder
I have model 2271 PAG 40 it seems to be stuck in some kind of display mode. switching from comp to baro to alt.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 22, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
The screen is swithing between compass - baro -
Feb 27, 2010 | Casio PAG40B-2V Wrist Watch
My Casio Pathfinder PAG-50 when I go into compass mode shows ---* is there a way to set the compass?
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Jan 01, 2010 | Casio Pathfinder Triple Sensor PAG501V...
open the backside.
Jan 13, 2008 | Casio PRG-40T-7 Pathfinder
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
