Computers & Internet Logo
Viv Sharfman Posted on Dec 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TIME MACHINE DOESNOT SEE SEAGATE DRIVE - Seagate Computers & Internet
Minister Ruland
Level 2:
Sergeant:
  • Seagate Expert 445 Answers
  • Posted on Dec 20, 2018
Minister Ruland
Seagate Expert
Level 2:
Sergeant:
Answers
445
Questions
0
Helped
127411
Points
810
You might have to go in and setup the drive. most new drives are not set up. you have to go in and setup the drive and format it for it to work
3answers
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
1helpful
My Seagate Expansion External Drive just stop working. Whene ever I connect the power cable it making bip sound repeately several times and stop. and the drive doesnot show in My Computer. The drive is...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
I have problem with my hard drive can not open, when i put in computer it doesnot show on .
it seems its not formatted - if you have Windows, try this:
Start > control panel. Then Go to Administration Tools (or somethine like that, dont have windows in english) and find Computer Management icon. Run it. Now explore to Disc management - there you will see your USB HDD. Click on them with right mouse button and create new partition, etc..
2answers
2answers
I use windows 95, it doesnot recognise my seagate external HDD
Dear! You have to install software of your external hard, after install the software or driver of your external hard it could be accessible.
Thank You
2helpful
Seagate 500gb Free Agent Ex Hard Drive - Class Action siut
DO NOT buy a Seagate freeagent drive under any condition if it comes as a gift return it or re-gift to some one you don't like. Like so many others my 500GB external drive just quit working. Has only been plugged in about 6 times and then back into a cabinet to keep safe. In 10 years between 2 workstations 3 laptops and 4 external drives. The only drives that have ever gone bad are the Seagates and newer Maxators. I still have 4 Western digital drives that still work and get used in an external case for back up. They have never failed. Seagate should be responsible for data time and mental anguish.
FreeAgent Drive Manager.app does not see drive-Mac
Turned out to be an easy one!! The Seagate tech had me reinstall the drive manager, and it then worked. But he did recommend using Time Machine, which I have, over their software!
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
