Are they compatible?
SOURCE: Sharp DVD disc error
I've found out that the recording speed is important for this model. The speed on the dvd must be 4x or less. If your using an 8x or 16x it will not work. Hope this helps.
Maybe you can help me. I'm looking for the 4 digit code that goes into the remote to make it compatible. I think it's in the operators manual, which I no longer have. If you can find this number I would really appreciate it.
SOURCE: Will not read disk recorded on Samsung DVD digital Camcorder
The disk needs finalizing.
However this then will make the disk unusable for anything else
Switch to CR R or DVD R as appropriate
SOURCE: Multi-function DVD recorder VRD-MC5
I had a similar no audio issue when using the I-Link connector and 8mm camcorder. I found that if i selected "Manual" rather than "Automatic" (copy everything) that I got good audio as well as video.
I have tried using a later model Sony miniDV camcorder with A to D passthrough from my 8mm Sony camcorder that I get better Video color using RCA cables directly from the 8mm Camcorder but better audio from the I-Link passthrough above.
Pogo
SOURCE: FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
SOURCE: Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
